When i put in the cd it says my printer isn't compatiable with windows 8
SOURCE: I just brought home a
run the set cd on lap top to set up the wireless. Check in printer if your printing to lemark (usb) it never print . print to (network) if it wireless if WI-FI GREEN / IF RED reset up software to enter pass code - your phone number is the best to setup
SOURCE: how to install my lexmark x1100 all in one printer without cd
follow the link and select which vista you are running.
http://downloads.lexmark.com/perl/downloads/downloads.cgi
Mark
First thing you need to do is uninstall the current software and printer.
Then go to: X1100 Series Driver
Select your operating system...Vista...from the drop down menu.
The next page has the link to download the driver. (It should be cjrX1100EN.exe. Click on "Download Now".
When you begin the download and the download window appears, select "Save" and direct the download to save to your desktop.
After the download is complete, close all the windows, or other programs.
Make sure your printer is ON but also that the USB cable is DISCONNECTED. Double-click the file on your desktop that you downloaded. When prompted by the software, connect your USB cable.
That should do it. If you run into any problems, just comment back.
Thanks for using Fixya.
SOURCE: Lexmark Prospect Pro 205 printhead error
where can order a new printhead for my lexmarkpro205?
SOURCE: I have a lexmark prospect
Updating the firmware for your Lexmark Pro200 series will help fix this problem. You will need to get rid of the error first before you can successfully update your printer. Follow these steps:
1. Open the cover of the printer > Remove the printhead. If the printhead will not go to the center, turn off the printer and pull the printhead to the center.
2. Once you have the printhead removed, close the cover of the printer and turn on the printer.
3. It will ask you to "Open Cover to Install the Printhead". Press the Cancel (Red X) button.
4. It should take you back to the "Copy" menu.
5. Proceed with the firmware update. Just go to http://bit.ly/p205fw. There'll be more than one download for your model, try the top download first.
6. Once the firmware update is successful, reinsert the printhead by following the steps on your printer screen.
Source: There is a Problem with the Printhead
