Texas Instruments TI-89 Calculator Logo
Posted on Jan 11, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I am trying to graph r=sqroot(sin2theta) on my ti-89 titanium in polar mode and it is telling me when i try to graph that there is an undefined variable. what do i do?
Anonymous
Level 1:
  • Contributor 8 Answers
  • Posted on Jan 30, 2009
Anonymous
Contributor
Level 1:
Answers
8
Questions
0
Helped
34150
Points
33
Did you still need help with this? My suspicion is a missing multiplication sign. Sometimes you need to be very explicit in what you want the calculator to do. Have you tried sqroot(sin(2*theta)) explicitly putting the multiplication symbol in there? I think 2theta is interpreted as it's own variable name...
Stevan Milanovic
Level 2:
Sergeant:
  • Texas Instru... Expert 267 Answers
  • Posted on Apr 22, 2017
Stevan Milanovic
Level 2:
Sergeant:
Answers
267
Questions
Helped
221961
Points
795
See the image below
How to restore memory on TI-89
Hard Reset means reset. Everything gone and no way to recover it.
1helpful
Ti-89 titanium diagnostics
There is no DiagnosticsOn command in the TI 89 Titanium. The command exists on the TI83/84PLUS where it displays the r and r^2 coefficients. On the TI89 , the correlation coefficient and the determination coefficient (r, r^2) are displayed by default among the statistics if THE REGRESSION MODEL includes them. If they are not defined by the regression model they will not be displayed. In short, you do not have to turn diagnostics ON.
TI 89 Titanium can not resolve indefinite integral of function arcsin(2*sqroot(x)/(1+x)). It is integrable function in finite form and partial integration giving solution...
Just a suggestion to you the expert.
You found a neat way to do something? Then write a TIP, clearly labeled so that people in need of this information will be able to find it.
It serves no purpose to pretend to ask a question and then answer it yourself. A TIP or HOW TO writeup will be the perfect venue for such a thing.
Sorry, I just did not want this illuminating procedure of yours to stay in the dark.
When I try to graph something, I see the graph, but I no longer see the x and y axis. This happened on my TI-89 titanium
Enter a function in Y= Editor, then draw its graph.
While the graph is still displayed Press F1
Press 9:Format to open the FORMAT screen
Toggle the Axes ON
I try to graph an absolute value on my Ti 89 and I put the inequality in right but when I go to graph it my calculator says undefined variable.
If you want to graph the absolute value of a function, feed the function to the absolute value ie graph y= abs(f(x)). The calculator will take care of it. See screen captures where I draw the function y1=x^3-5x^2-3 and y2='x^3-5x^2-3'. On the first graph the function is represented and on the second the function and its absolute value.
The calculator knows how to calculate the absolute value of an expression. The name of the command is abs(
1helpful
Integrating 1/root(10-x^2) from -root(10) to root(10) gives pi on the TI-89 but gives undefined on the platinum TI-89. Why and is there a way to make it work on the platinum?
I am aware that this does not fully answer your WHY question but it may help you decide what to do.
On the TI92 Plus, which has the latest OS for that machine 2.09 Advanced mathematics Software one gets the result Pi in EXACT or AUTO modes and 3.1415926536 in APPROXIMATE mode.
However when in EXACT/AUTO mode the calculator displays a warning message Memory Full, Simplification may Not Be Complete. (see screen capture.)
On the Voyage 200 PLT with OS version 3, the same as on the Titanium (not Platinum), I get an undefined result in EXACT MODE and 3.1415926536 in APPROXIMATE MODE.
So you can get the approximate value of the integral on the Titanium or the indefinite integral which you can evaluate between the two boundary points.
My TI-89 Titanium won't graph sin, cos, or tan?
Set your calculator to RAD mode and then graphing functions.
See example for y=sin x
4helpful
All trig-based graphs give me weird results on my TI-89 Titanium. Taking y=sin(x) for instance, I get a clean diagonal line through the point (0,0), almost resembling the graph y=x with window xmin = -10...
You have your angular mode set to degrees. Ten degrees is about 0.17 radians, and for small x: sin(x) is nearly equal to x. Thus, sin(x) from -10 to 10 is indeed nearly a straight diagonal line.
Press MODE, then scroll down to "Angle" to change the angular mode.
4helpful
2answers
I cannot plot graph in my Ti 89 graphing calculator
That means one (or more) of the variables you have in your function is not defined. Check to make sure you didn't misspell any variable name. Also, check to make sure you didn't run two variable names together. "ab" is the variable ab, not a times b.
5helpful
3answers
Graphing radical functions
I have a TI-89 Titanium and I have experienced the same problem. HERE IS HOW TO FIX IT:
Goto " MODE " and scroll down the options until you get to
" COMPLEX FORMAT " change that option to " RECTANGULAR " and press ENTER until you exit out of the " MODE " screen. (very important that you press ' enter ' until you exit because if you don't, it will not save your changes. )
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Jerry Naidoo
Paul Bade
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
