I have a Canon PIXMA MP780/MP750 Printer. Until recently it has produced beautiful color prints. I replaced the BK cartridge, went through all the maintenance, cleaning, deep cleaning, alignment, etc. Color is primarly blue, green. No red, little yellow. At my witzs end.
If the resultsprint outlikethis,there are twopossibilities: 1.Redinkin thecartridgeruns out.Solution:injectingwithredink 2.If theredinkhas beenfilled,andcheckpatternis stillnotout, meaning thecolorcartridgeerror.Solution:replace thecartridges
Have you checked to see if the jet area on the bottom of the ink cartridge has a blackish sludge on them? It might be that the area that the print cartridges are purged/cleaned to one side of the printer (sometimes called a service station, or spitoon) has built up excess ink that has gotten thick and high enough that as the carriage goes over that area the bottom of the cartridge gets polluted with the blackish sludge. It will work slightly into the jets where the ink comes out and cause discoloration, even after you change the color cartridge. Open the unit to look inside with a flashlight for build ups and clean it (if you find some) with disposable things like cotton swabs, coffee stirrers, whatever you have that wont damage anything inside. Another cause could be mixing of the cyan and magenta and yellow somehow inside making a dark color representing black - but replacing the cartridge would cure it immediately.
This is where the serial number is located, look here.
Locate the Serial Number
The serial number of the PIXMA MP750 / MP780 is located at
the back of the printer towards the bottom edge, as shown below.
The serial number for the MP750 starts with three
letters (AGA) and ends with six numbers. Example: AGA012345
The serial number for the MP780 starts with three
letters (AHB) and ends with six numbers. Example: AHB012345
I think you are seeing "ERROR 5100: Cartridge Jammed", right?. Here is the most likely solution to this issue with your printer. The following procedure comes directly form Canon
ERROR LCD: CARTRIDGE JAMMED
when they say TONER , its refering to the INK CARTRIDGES , Color & black ,
CANON PIXMA MP780 & MP750 uses the same INK CARTRIDGES :
BCI-3eBK for BLACK & BC-31C for color
PIXMA MP780 "WRONG CARTRIDGE" MESSAGE? Here is what I did and it now works just fine.I turned off the printer and unplugged the power cord, and unplugged it from my computer. I then removed all the ink cartriges and removed the print Head I got some rubbing alcohol put it on some toilet paper and wiped down the back and bottom of the print head.Plugged everything back in and It now works better then ever.
