I have a D-link DI-614+ wireless router which has been on the shelf for about 4 years. I have had to call it back to duty due to some unfortunate incident involving a power supply failure and after a series of other problems, I'm unable to use our Ethernet.connection. So, I need to go wireless temporarily. I assume that the setup is O.K. and I am using the same D-Link DWL-G122 Wireless G USB adapter that was used back in the day. When I try to reach the router via http://192.168.0.1 it asks me 'A username and password are being requested by http://192.168.0.1. The site says: "WebAdmin"'. I would like to know how to retrieve and change, that Username and Password. The DWL-G122 wireless adapter seems to be working because it found it found 8 wireless networks, including ours, All 8 networks were "Secured". Oh! Oh! That password has been long forgotten also. I need to know how to retrieve, as well. Thank you, anyone out there that can help.
SOURCE: No internet connection through router D-Link DI-524
Lost internet connection morning of 1/15/08 through router and directly through laptop 1. But, can get internet connection directly for laptop 2 and laptop 3! Cannot get a valid IP address anymore when laptop 1 is directly connected. Also, I discovered ping works for any lettered website even when the router is not connected to the wall, but correctly times out for a numbered website (eg 216.31.156.10). Completely stumped. Please help!
SOURCE: Internet connection lost when wireless printer added to network
for reseting the password of ur dlink router u have to press the rest button on the dlink router (genrallyit on the bottom or on the back of the router it is like a hole u have to use a pen or pin to reset the router back to its factory default settings after that password of the router will automatically back to admin or password login to ur router change the settings to static ip in the router so that u can provide the static ip of the other router to ur this router (example if primary router HL 2170 ip address is 192.168.1.1 then u will provide this dlink router the ip address as 192.168.1.5, subnet 255.255.255.0 default gateway 192.168.1.1 primary dns 192.168.1.1 now save the settings in the dlink router now the ethernet cable from ur other router will go directly in to the internetor wan port of this router. now connect wirelessly to any router both will work fine without any problem
SOURCE: D-Link AirPlus DI-524 Wireless Router pass and username
Default IP: 192.168.0.1
Default username: admin
Default password: *blank*
