Sony KP-46WT500 46" Rear Projection HDTV-Ready Television Logo
perry banister Posted on Dec 01, 2012
What size speakers and where to get them - Sony KP-46WT500 46" Rear Projection HDTV-Ready Television
Anonymous
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Apr 26, 2013
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
301
Points
2x2" tweeters and 2x5 1/2" as for watts and ohms I can look and see
  • Anonymous Apr 26, 2013
    2x as in quanitity.
Color meaning on 2004 Chevy LS 2500 radio wiring harness
2004 Chevrolet Silverado March 31st, 2012
Posted in Chevrolet Silverado
2004 Chevrolet Silverado Stereo Wiring Information
Radio Constant 12V+ Wire: Orange
Radio Ignition Switched 12V+ Wire: Class 2 Serial Data
Radio Ground Wire: Black/White
Radio Amplifier Trigger Wire: Pink
Left Front Speaker Wire (+): Tan
Left Front Speaker Wire (-): Gray
Right Front Speaker Wire (+): Light Green
Right Front Speaker Wire (-): Dark Green
Left Rear Speaker Wire (+): Brown
Left Rear Speaker Wire (-): Yellow
Right Rear Speaker Wire (+): Dark Blue
Right Rear Speaker Wire (-): Light Blue
2004 Chevrolet Silverado Speaker Sizes
Audio Front Speakers Size: 6.5?
Back Speakers Size: 4? x 6?
The following information is currently not available:
Radio Illumination Dimmer Wire
Radio Antenna Trigger Wire
Front Speakers Size
Rear Speakers Size
https://www.google.com/search?q=2004+Chevy+LS+2500+radio+wiring
1helpful
2answers
Bought new Infinity 8" speaker
hook them up and play something,, the speaker should bounce "out" on bass sounds, if it pulls "in" switch the wires
What is the color code for the speakers 2004 chevy silverado 4x4
Left Front Speaker(+) TAN ; Size: tab_tech.gif Left Front Speaker(-) GRAY ; Size: Right Front Speaker(+) L GREEN ; Size: Right Front Speaker(-) D GREEN ; Size: Left Rear Speaker(+) BROWN ; Size: Left Rear Speaker(-) YELLOW ; Size: Right Rear Speaker(+) BLUE ; Size: Right Rear Speaker(-) LT BLUE
[email protected]
What is the voltage polarity ac or dc of the power adapter for SP-613 speakers?
this is actually the product description for your speaker
Product Description
Front
Speaker Unit: 1inch +6.5inch *2+8inch
Power: 10-100W
Sensitivity: 88 dB
Impedance: 4 ohm
Frequency Response: 45-20K Hz
Production Size: (H*W*D) 1087*210*336mm
Package Size: (H*W*D) 1162*500*400mm
CENTRE
Speaker Unit: 1inch +4inch *2
Power: 10-60W
Sensitivity: 86 dB
Impedance: 8 ohm
Frequency Response: 75-20K Hz
Production Size: (H*W*D) 160*500*179mm
SURROUND
Power: 10-60W
Sensitivity: 85dB
Impedance: 8 ohm
Production Size: (H*W*D) 225*160*158mm
Package Size: (H*W*D) 550*273*415mm /3PCS
ACTIVE SUBWOOFER
Speaker Unit: 10inch
Impedance: 8 ohm
Crossover Point Control
Handling Power: 120W
Production Size: (H*W*D) 405*328*350mm
Package Size: (H*W*D) 465*330*465mm
I need a diagram of the wiring for a 97 mercury cougar to in stall a aftermarket stereo i dont know wat wires to connect to each other
Left Front Speaker(+) ORANGE/L GREEN ; Size: tab_tech.gif Left Front Speaker(-) L BLUE/WHITE ; Size: Right Front Speaker(+) WHITE/L GREEN ; Size: Right Front Speaker(-) D GREEN/ORANGE ; Size: Left Rear Speaker(+) PINK/L GREEN ; Size: Left Rear Speaker(-) TAN/YELLOW ; Size: Right Rear Speaker(+) PINK/L BLUE ; Size: Right Rear Speaker(-) BROWN/PINK
1helpful
What is the other smaller gauge orange wire locat
Smaller gauge orange wire is a dimmer wire. If the radio you are installing does not have a dimmer wire, just tape it up.
Hope this helps.
Rating appreciated.
10helpful
4answers
Need Radio wiring diagram 2004 chevy silverado 2500hd (oem plug)
Yellow -ignition
Orange-Constant +12 volts
Black - ground
If you need more info, please ask.
A rating is appreciated.
OEM speaker sizes on 2008 F-150 ext cab
i belive the are around a 6 inch speaker tale out ur original speakers and measer across the speaker or if they are the crazy looking shape then i would take the original speaker down to the store u are going to and ask someone to help u find the shape and size
What size speakers do I get to fit a 1990 Nissan
Your front door speakers are 6 3/4" http://www.crutchfield.com/S-K6CgySFIW3q/app/car/mycar.aspx This link will show all the sizes for your car. Do note though that the rear speakers are not a standard size. Hope this helps :)
2answers
Speaker size
Hello p_altamira,
Here is a link to the SonicElectronix database for speaker sizes.
https://www.sonicelectronix.com/chevrolet-malibu-2005-car-speakers.html
Hope this helps.
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
