When I type in a question using roots my calculator does not leave the answer in surd format. E.g. when you type in 2 x root 5..... the calculator used to give me the answer 2root5 (surd format) then I'd press S>D to get the decimal answer. Now when i do calculations in an exam and it says leave the answer in surd format I wont be able to do it. I must of fiddled about with the settings and messed it up. I'm finding this really annoying, could someone help. Thanks.
Thanks for the sharing this idea with us because we have need so much of this https://windowsclassroom.com/how-to-switch-users-on-windows-10 article and i am sure if all user will be see tis article then they will be also happy.
SOURCE: Hi there, I have a
The calculator can't identify that this is a surd unless you input it as a surd, ie as 3/(4*sqrt(5))= when it will then show the equivalent form 3*sqrt(5)/20 (obtained by multiplying top and bottom by sqrt(5)) and you can swap between the two forms using the S<>D button. Even adding the next 4 decimal places (hidden) won't allow the calculator to identify the underlying surd as this is simply too complcated a calculation.
Change the output display to MathIO. You may be able to display square roots only: so no cube roots, nor fourth...
its okay i fixed it ---------- For those who want to know the solution its shift MODE --- then press 1 and then 1 again.
The calculator will not be able to determine the underlying surd even if you add the following four (hidden) decimal places. the backrooms
the backrooms
