SOURCE: My suzuki gsf 600 bandit 1999 wont start.
Hi and welcome to FixYa,
Initially, try with the sidestand folded up and / or the clutch lever pulled in. Likewise determine if there is a clicking sound when the start button is pressed:
It is of course assumed that the battery is fully charged and that the battery cablles/connectors are clen and tight. Postback result(s) of tests.
Good luck and thank you for asking FixYa.
SOURCE: Suzuki bandit 1996 will not start
could be the safety switch on the clutch leaver. Turn bar's full right, then left a few times and give it a go.
SOURCE: Starting fault
There is also a safety switch on the clutch lever that could give the same symptoms.
Another thing to check is the fuse block that has a starter relay built in (hidden) above the fuse compartment. My D5 has the same symptoms and this is the problem. If I keep the starter button depressed for some seconds the relay operates and bike starts.
