Kodak EasyShare Z612 Digital Camera Logo
Posted on Dec 01, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Viewfinder won't open
Anonymous
Level 3:
Genius:
  • Kodak Master 1,019 Answers
  • Posted on Jan 24, 2013
Anonymous
Kodak Master
Level 3:
Genius:
Answers
1019
Questions
0
Helped
102594
Points
1576
Hello, I don't have the manual for your Z612 in front of me at the moment but does this model not have a small button marked EVP/LCD
near the LCD screen ? If you press the button it should switch from the LCD screen to the viewfinder.
My LG washing machine door won't open
UE is unbalanced load. Unplug machine for 5 minutes then plug back in. That may cause it to unlock.
2helpful
My camera won't focus!
While looking through the viewfinder, turn the diopter adjustment knob just above and right of the viewfinder to adjust it until the focus marks and other information in the viewfinder become sharp to your eye.
I advise a high school yearbook and we shoot a d100. Today it's too dark to see through the viewfinder (yes the lens cap is removed), and i ger the r06 error. I've reset the camera, removed and...
First, the "r06" message is NOT an error code. It indicates the number of shots remaining in the internal memory buffer, before the camera must prevent additional shutter actuations so that it may transfer those images already in the buffer to the memory card. This "r" number will decrease with each shot taken in rapid succession until it reaches 0. The shutter release will no longer work until the buffer is transferred to the memory card, then shooting may continue again.
As far as not being able to even see through the viewfinder, it sounds like something may be obstructing the light from reaching the meter and viewfinder. The problem is most likely the position of mirror inside the camera body. With the lens off the body, the mirror should be plainly visible at about a 45 degree angle to the opening. A side view drawing of this is below. The solid red line is the mirror in the normal position. The red dashed line is the up position of the mirror when the shutter is released.
When the mirror is in the "normal" position, the light from the lens is projected on a screen so that the image is visible in the viewfinder for composing and can be metered. When in the "up" position (when the shutter release is fully depressed), the light from the lens is projected on the camera's sensor for as long as set by the manual settings or program; based on ISO, aperture, etc. At the end of this time, the mirror returns to the "normal" position.
If your D100's mirror is not in the lowered 45 degree angle position, the image seen in the viewfinder is inside the camera - not that which the lens would project. Hence, the dark viewfinder, long exposure times and - I'm guessing - severely overexposed pictures because way too much light is striking the sensor because the meter is only seeing darkness.
If the mirror is ok, with the lens removed from the body, look for the aperture lever as shown in the yellow circle in the picture below:
By default, the aperture is at minimum. The camera moves the lever from this position to full open (and anywhere between) as needed. You should gently move the lever to the other end of its travel to open the aperture to maximum. Point the lens away from a light source but preferably at a light colored background. Look through the lens. There should be no obstructions and be clear. Next, look at a dark colored background to find the same results. If you want, you can even allow sunlight to shine through the lens onto a sheet of paper (like a magnifying glass). The result should be a bright circle with no obstructions. Obstructions in the lens will prevent the meter in the camera from getting accurate information about the scene and if significant enough, prevent viewing through the viewfinder.
You may wish to have the camera & lens professionally cleaned and serviced to repair a mirror or lens issue.
If this was helpful, please rate it as such. Good luck!
1helpful
Can I look at the viewer instead of the small eye viewer?
You can look at it but you won't see anything. If you want to see what you're shooting, you have to use the viewfinder.
My 2000 licolin battery died the key won't open the door lock how do get in to the engin to put jumpers on the battery to give it enough power to work the locks ps i don't understand why the key...
The key has to open the drivers door
Raise the car up,support it,& put your battery
charger on the starter battery cable terminal
& ground the black clip
Try charging the battery for 4 hours or so
Top Kodak Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Kodak Camera Expert? Answer questions, earn points and help others
