USTVNOW.COM DVD Feature Stopped performing properly over 1 Wks. Unable to Access and Watch Any Recorded TV Shows. Without Screen Causes a QUICK FLICKER Twice... Fast. When clicking the Remote Control to PLAY. The TV Screens Shows the Name of Show & when I press PLAY. "Play from Beginning or Resume Playing" then FLICKERs RETRIEVING... Then NOTHING!... Right back to the Screen to "PLAY FROM BEGINNING" - Option!..) I have Notified the TECH SUPPORT of my Concerns. They cannot seem to Figure the Problem or Why this is Happening,. I am Able to WATCH LIVE TV, Most times. Unfortunately it is the DVD FEATURE that I want to WORK MOSTLY!... I Have made SEVERAL ATTEMPTS to 'RE-Install Software & 're-about WiFi Modem. Everything Else works GREAT! And able to Watch ALL OTHER "ROKU CHANNELS" with No ISSUES,.... HELP! ANY IDEAs?.... (Been an Overall Proud Customer on an Overall basis! Getting Paid Cable Most 6-months)....
SOURCE: TIVO Remote Control Problem
A similar problem happend to me. Buying a new remote fixed it - for about three weeks.
Maybe your new one will work longer.
SOURCE: remote programmed: not all buttons work.
No so-called 'universal' remote will give you all the functions found on the original.
Your Symphyoinc is made by Funai who now owns the name rights in the US.
Try any codes you might have for the Funai name.
In addition:
I wish someone would bring a suit against any of these manufacturers using the term 'universal.'
At best, they are 'multibrand' and, with the proliferation of 'brands,' there never will be one that can rightfully claim to be 'universal.'
There may never be a code for your brand available in every remote.
SOURCE: My Toshiba SE-R0161 Remote no longer works.
There is most likely nothing wrong with your remote. I just had exactly the same issue with my SE-R0161 remote. (I had just changed my remote batteries too and was getting a DR-2 code on the Toshiba DVR RD-XS52 unit's display.) My DVR and my remote had to be realigned so that they both have the same infared (IR) code. The remote and the DVR can have DR 1, DR 2 or DR 3 as remote codes. Pg 54 of the Toshiba Installation Manual explains how to align both your SE-R0161 and your based unit so that the remote works again. Good luck. Hope this helps.
SOURCE: the list button doesn't work and I am unable to
turn off your cable box
turn off the dvr
disconnect cable box from wall outlet
disconnect dvr from wall outlet
unplug e-sata cable from dvr
replug e-sata cable back in to dvr
plug dvr into wall outlet
turn on dvr
plug in cable box to wall outlet
turn on cable box
wait for cable box to go completely thru startup procedure
...then try your list button again.
