Battery
SOURCE: Don't know how to open door latch on nikon 35mm SLR camera
You haven't stated which model you have, but generally most SLR's open by pulling upwards on the film rewind crank (the knob on the left side of the top-plate as viewed from behind). If this doesn't work then add the exact model as a comment to my answer and I'll try to give you specific instructions for your model.
SOURCE: I have a Nikon N90s /film 35mm slr. I haven't
If the switches and contacts are dirty that would do it. If that happens the cost of service may exced the cost of buying a used one.
SOURCE: what type of battery do i need for a 35mm nikkon
Two SR-44, S-76, or LR-44 batteries OR one CR-1 3N battery, assuming you really mean the FG. Other Nikon 35mm cameras may need other batteries.
SOURCE: My Nikon fe slr camera's film winder wont wind on
Having received no response in over a month, I assume this is no longer a problem.
SOURCE: I'm looking to buy a
Yes, as long as it's not a DX lens. DX lenses are designed for the smaller image area of some digital cameras and will cause vignetting (dark corners) on a 35mm camera. The vibration reduction feature of VR lenses won't work, but won't cause any problems.
DX lenses will fit and work, but as mentioned above, you will get dark corners.
Testimonial: "Thanks!!"
