White screen with apple have tried holding down shift key on start up but still no luck and can't find original disks! Any suggestions?
SOURCE: MacBook won't start up.
If you have your Mac OS X Install disc, insert it into the drive.
Restart the computer and hold down "C" while booting.
Choose your language.
Select "Disk Utility" from the "Utilities" in the menu bar.
Select your Macbook's hard drive in the left sidebar.
Click the "First Aid" tab thats along the top of the viewer window.
Click "Verify Disk" (not verify disk permissions)
If this shows errors click "Repair Disk"
Once completed close the Disk Utility window.
Restart the computer.
If this fails to fix it as well then your next option would most likely be recovering your files from the macbook either by booting into target disk mode (hold down T at startup) and transferring them via a firewire cable, or removing the hard drive and hooking it up to another Mac to get the files. Then do a clean install of Mac OS X using your installation discs.
SOURCE: Apple MacBook 13"White....want to download drivers
hi,
I am not sure where you looked, or if you checked the Sony website, but here is a link you might want to check out:
http://esupport.sony.com/US/perl/model-s...
I hope this helps,
SOURCE: completely white/gray screen
First try this: shut it down, disconnect the power cord, pull out the battery, then hold the power button for a full 10 seconds. Reinstall the battery, reattach the power cord, turn it back on.
Still doing it? Put the reboot disk that your Mac came with, or the disk to the version of Mac OS X that you're running.
To start from disk hold "C" as your Mac is first turning on from a complete shutdown.
Dan Crowley, iKnowApple.com
919.280.3101
SOURCE: Turning on my macbook- all i see is white screen and 'no' sign
Apple has a troubleshooting document about this here:
http://support.apple.com/kb/TS1892
Normal procedure is to reset the NVRAM and PRAM then "remind" your Mac where to find the system folder. (This problem sometimes happens when the system folder is moved, renamed or deleted.)
It may be necessary to reinstall the operating system. (Fortunately, if you use the "archive and install" option, you can do this without erasing the hard drive or losing your user data.)
SOURCE: Grey Screen Apple Start up issue
It appears there may be a possible startup item or issue with your firmware, which may be causing this issue, so I am going to provide some procedures in order to help you resolve this gray screen issue. But first, let me help you remove that disc first:
font.f1 {font: 13.0px Myriad Pro}
font.f2 {font: 14.0px Myriad Pro}
Procedure #1 - Ejecting CD from drive
Here are some steps I recommend you try to resolve the issue with the disc not ejecting properly
• Reboot your Mac
• Hold down your Mouse button(s) prior to the Apple Chime
• Keep holding the mouse button down while your Mac boots up
• The disc should eject before you reach your Desktop
• When it does, simply release your mouse buttons.
If this does not help resolve ejecting the disc in your Macbook's drive, you are going to have to take more of a command-line approach:
font.f1 {font: 12.0px Helvetica}
-EJECTING DISC USING TERMINAL-
From your Desktop:
•Click anywhere on a blank space on your desktop. Now you should see Finder listed near the Apple menu icon.
• From the Finder menu, click on Go, then Utilities from the
drop-down menu. This will take you to your Utilities folder.
• Locate and open the Terminal utility
• At prompt, type: drutil eject
• Now press the Return key on your keyboard
(NOTE: If you have a CD/DVD drive with a tray, type: drutil tray open press the Return key on your keyboard )en
• This command line should eject the disc from the drive, unless there are mechanical issues with the drive within your Macbook.
At this point the disc should be ejected from your Macbook. If this is the case, then I will now need to direct you back to Safe Boot mode, but with a little twist, from what you may have tried when you last when to Safe Mode:
I am going to have you take your Mac into Safe Mode to see if we can't remove a possible folder(s) that may be affecting your Mac's start up function.
Try these steps:
-SAFE BOOT MODE-
• Reboot your Mac
• Upon restarting your Mac, press the Shift key.
• Hold the Shift key until you see a White Screen with Gray Apple icon and eventually a spinning gear.
• When you see the Spinning gear, release the Shift key.
• Allow the Mac to continue booting up. Also this may take a little while.
(NOTE: this may take anywhere from 5 to 15 minutes to load to the Safe mode screen depending on the performance of your Mac, but if it exceeds this time, shutdown your Mac and try just once more. It may have just frozen up the first time around for you.)
• You are going to enter the Safe Mode (which looks like your main desktop environment the only difference is certain start up items are disabled.)
• Once within the Desktop in Safe Mode
• From the Finder Menu, click Go> Go to Folder
• Type in this line: /System/Library/StartupItems
• This path, is going to take you to the System Library folder which has all of your Mac OS X Startupitems.
• Remove all of those folders to the Trash.
*Reboot your Mac normally and see if you can access your normal User desktop environment.
Post back to me, if these particular Safeboot procedure does not help. Thanks!
Regards,
-Mactechtrainer
1. If computer is on, turn it off by choosing Shut Down from the Apple menu.
2. Connect power adapter to computer and to a working power source.
3. On built-in keyboard, press (left-side) Shift-Control-Option along with power button just once. Important: Use Shift-Control-Option keys on left side of keyboard.
Note: When the LED on the MagSafe connector is orange/amber, resetting the SMC will change it to green for a few seconds, indicating that SMC was correctly reset.
4. Wait 5 seconds and press power button to start computer.
If it starts without beeping errors reset the PRAM (Parameter RAM)
p.p1 {margin: 0.0px 0.0px 0.0px 0.0px; font: 10.0px Helvetica; color: #1a1a18} span.Apple-tab-span {white-space:pre}
1. If computer is on, turn it off by choosing Shut Down from Apple menu.
2. Locate the following keys on the keyboard: Command, Option, P, and R. You will need to hold these keys down simultaneously in Step
4. Note: If keyboard does not have an Option key, use Alt key instead.
3. Press power button.
4. Immediately press and hold Command-Option-P-R keys.
Important: You must press this key combination before the gray screen appears.
5. Hold down keys until computer restarts, and you hear startup chime a second time.
6. Release keys.
p.p1 {margin: 0.0px 0.0px 0.0px 0.0px; font: 12.0px Helvetica; color: #1a1a18}
