I lost my dvdcd nero burner when i canceled an update for it even the icons are gone the program is no longer listed where did it go??
Click start
control panel administrive tools,computer management,device manager scroll down
cd-dvd rom drives you might see a yellow question mark ? right click you
will have options to update driver,roll back driver,or select properties
general troubleshoot, select driver click to reinstall drivers click update
driver or uninstall then reinstall if this does not fix the problem it might be
a registry problem if you cant see your disk drive in windows explorer
Close all open
programs
Click on
Start, Run, and type regedit and press
Enter
Click on the plus signs (+)
next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder
is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the
following names in the right hand column.
Upper
Filters
Lower
Filters
Upper
Filters.bak
Lower
Filters.bak
If any of the above keys shown in step
4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and
check to see if your CD or DVD drives have returned. You may also want to open
Device Manager and verify that the yellow exclamation and error code on the CD
or DVD drive is gone.
hope this helps
