Akai PT5598HD 55" Rear Projection HDTV-Ready Television Logo
Posted on Jan 11, 2009
AKAI PT5598HDI 55" PROJECTION TV HAS POWER AND SOUND, NO PICTURE
ILL TURN ON THE POWER AND I GET SOUND BUT NO PICTURE, CAN ANYONE HELP WITH THIS?
  • carisdaddy Jan 11, 2009
    WHERE ARE THE FUSES LOCATED?
  • Steve Masi Apr 06, 2009
    So do you know if it is the fuses because I have the same problem.
Anonymous
Level 1:
Problem Solver:
  • Contributor 14 Answers
  • Posted on Jan 11, 2009
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
14
Questions
0
Helped
3056
Points
21
Open the back of the tv and check Fuses, sound like the high volt over loaded
AKAI PT5598HDI Colors out of line and picture is bowed in on bottom and top.
http://www.fixya.com/support/t1663670-akai_samsung_pt4299hd_convergence Adjust the convergence manually. It's a pain and takes alot of patience. The diagram for the remote buttons helps a lot. If it won't adjust you'll have to replace a part inside the tv. Good luck! Hopefully it'll adjust.
1helpful
Akai PT5598HDI Rear Screen Projection TV With Blue Shadowing
If the ghosting is like a 3D effect its your convergence ICs , but if its like a blue Halo around objects that usually means your CRT coolant has congealed and will need replacement. The blue is the first tube to congeal for some reason, followed by green. Red seems to be not quite as prone to this. It is a normal occurrence n sets about 4 years old to need the coolant changed.
1helpful
AKAI PT5598HDI 55 Where is fuse located
This problem is beyond a blown fuse most likely. The fuses for the unit are located on the circuit boards and the back will need to be removed to access them. This problem could be due to a missing voltage that is used to turn on the picture section of the electronics. I would search for a used unit on ebay or parts on ebay and swap out the boards. The board swap is not too complex but voltages are dangerous within the set and service by a qualified electronics technician is recommended on this unit. Thanks and good luck. Dan
I have the 55" phillps rear projection tv
Common problem with this model. Goto www.TvRepairKits.com to get their chirping TV repair kit.
PT5598HDI Wiring Problem
the red wire will go somewhere to the right side near the High Voltage section. The green wire is probably antenna. DO NOT get them crossed...
Question. what connector if any is attached? The board will usually have a pin sticking up that is marked...
1helpful
PT5598HDI
More likely Icz103 & Icz104 the convergence amps. Are they heating at all?
Bill
Akai PT50DL24 50 in DLP Rear Projection TV-NO PIC OR SOUND
check for popped or raised tops on caps in power supply. also try unplugging set for 5 minutes and resetting it. How about does your color wheel spin up? if your color wheel don't startup then your tv will also shut down. also check all fans they all should be running at turn on. if all fails i would say its your light engine.
No power to the television
Dont know if this will help, try leaving it unplugged over night, thaught I saw that solution in a blog somewhere a while ago.
Top Akai Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Accurate TV Repair...
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
