We have a GE Profile side-by-side (model PSS265HRB SS) that has been making an intermittent "howling" sort of flow induced noise.
It appears to be more prominent from the freezer side than the refridgerator side. I have not been able to determine if it is associated with the evaporator fan or with the internal refridgerant piping.
SOURCE: My GE side by side refridgerator makes a "howling" sound. Any ideas?
the problem you are having is in the main control board. ge has had a problem with this part causing the fan motor to go into high and low speed which causes the howling noise. unfortunately it is a costly fix, around $125 for the part. if you are savy to changing this part it is a matter of unplgging about 5 connections and replugging them. the new board has an extra set of pin that nothing connects to. READ the instuctions and it is a simple fix, saving about $50-60 in labor costs.
SOURCE: evaporator freezing up on my ge gss25tsrd refridgerator
YOU CAN SEE HEAVY FROST ON THE REAR OF FREEZER WALL?
SOURCE: GE Refridgerator Not Dispensing Water
The waterline inside the door is frozen . Best way to thaw is .....1. open the door and tape the light switch down to keep the light off and the fan working . 2. tape plastic (trash bag , drycleaning bag..etc) over the entire freezer opening so the food will not thaw and the fridge will continue to work as designed . If possible 3. disconnect the water coupling behind the kickplate so air can enter , helping the door defrost cycle , or , leave the coupling connected and ocasionally walk by and press the water dispensor to see if thawed . 4. turn your freezer setting to a lower temperature ! to keep this from happening again .
SOURCE: I have a GE refridgerator
I believe all you need to do is purge the air from our new water filter. Thanks, Sea Breeze
SEA BREEZE APPLIANCE PARTS
SOURCE: ge fridge pss26sgrc ss is making a
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
My haunted GE Profile refrigerator Model ( PSS26SHRB SS ) makes the same noise.
