I cannot get my printer to print borderless copies of various projects such as cards, calendars, ant etc. I have changed thee page setup on my projects, but cannot change the borderless printing on the Brother printer.
SOURCE: Brother MFC-5440CN Printer Problem
If this only happens when you are copying.
1. Your scanner glass is dirty. Open the lid, use windex to clean the
flatbed. Look on the left side. You should see a strip of glass, with
the scanner sitting under it. This strip is used when the document feed
is being used. Make sure it is clean. Most common problem is getting a
little whiteout or the sticky residue from scotch tape on this glass,
which causes lines down your copies.
Clean it with alcohol which will dissolve the sticky stuff and the whiteout.
If this does not solve the problem, the CCD scanner in your machine might be going bad.
SOURCE: Brother HL 1440 Printer Density Adjustment
Go to Printer and Faxes and select the properties button, then select the maximum dpi in the Advanced tab. You will get the best quality Print
SOURCE: Brother Intellifax 1820c fax machine: Won't print incoming transmissions
How do you fix the error 41 that keeps showing up
SOURCE: My Brother HL-20 laser printer
All laser printers have 2 cylinders in the image..the mag roller, and the drum.
Usually the drum is marked by a foreign object e.g label or someone has touched it with their finger.
If you replace the cartridge your problem should go away
