SOURCE: door locked and won't open
Hello and welcome to fixya. The "E13" error code on the WFMC series Bosch washer`s refer to a drainage problem as you may or may not already know. ( or in Bosch terms "pump time exceeded" ) What you may have is either a clogged pump, improper detergent being used, ( must use "HE"/lo-sudsing detergent ) hence suds not allowing a proper drain cycle, or wires loose at the pump...the later being the least likely. You haven`t mentioned if you`ve checked the pump...just hoses as you did mention. Anyway, here`s the most likely way to remedy a E13 code. **Unplug the washer from the wall or turn off the breaker before attempting any repairs** Get some towels and if possible a wet/dry vac. If the machine drained, it won't be too bad. If your machine is stuck full of water, I can't say, hopefully you won't get wet. ( maybe you`re lucky enough to be close to a floor drain ) Locate the round door on the front of the machine (about 6" in diameter, lower right corner) Find a drill bit or small screwdriver that fits in the hole in the round door. Insert the bit into the hole in the door. It will push in a tab, it doesn't take much force. Rotate the hole (clockwise) to 6'oclock and it should come free. (the edges are very sharp so be careful or wear chain-mail gloves). Once the door is out of the way you'll be greeted by a 3-4" plastic cap with wings so you can unscrew it by hand. ( you should also see a red ring with a string attached, if you pull this the door should unlatch, but getting the water out first is usually a good plan ) There is a small collector lip at the bottom of the cap, that is where you can hold the wet/dry vac to catch the water. Unscrew slowly so you don't get flooded, until it is unscrewed all the way out. Now pull out the trap and visually inspect the inside of the pump as well as the filter/trap. Hopefully you'll find the item/debris that initiated the error code. After removing any debris or obstruction`s re-install the button trap/lint filter and plug the washer in to power or reset the breaker and give it a test. Run a load and watch for leaks. Leave the pump access door off until you are sure you screwed the cap in tight and there are no leaks. Ultimately you may have a faulty drain pump, but I would certainly start by performing the things I listed first. Let me know if you require further assistance and if not and this indeed solves your problem, please rate the solution I provided accordingly. Thank you for coming to "fixya" and good luck. macmarkus :)
SOURCE: Bosch Nexxt 800 washer won't drain clothes fully
There is not a Spin Only Cycle BUT there is a REFRESH cycle that will take about 10 minutes.
Sometimes when the load is unbalanced and the machine can not balance the load by itself, the clothes will remain soaked. To avoid this, make sure you always have a balance of small and large things and when loading your machine, do not shove the items in so they ball up.
SOURCE: Bosch Nexxt 100 series washer stops at 1st spin cycle
take a look at your manual that came with your machine go to problems usually at the back and see what that says,or go to the bosch website and type in your model number its on the inside of the door.i would suspect a program fault.adrian,,,,,
SOURCE: Bosch Nexxt 300 has error
Turn the dial to off position wait few second, door should unlock. Unless you try to open it during cycle, it won't open. Otherwise, follow owner manual. call the manufacture.
SOURCE: I have a Bosch nexxt
Check for voltage to the water valve when starting wash cycle. If no voltage replace main control.
Hello &
Welcome to FixYa
E13 error in
your Bosch WFMC washer is a drain error and is displayed when the drain time
exceeds & the washer is unable to drain so the door won't open sometimes
when this error is displayed. You will have to clean the drain trap in the
bottom right hand corner. You can stick a straighten paper clip in the access
panel located inside the front bottom panel through the whole and then turn the access
panel counter clockwise to unscrew the plastic drain cap behind it. After
everything is cleaned and the error returns then replacing the drain pump is
recommended repair. Please get back to me if you have any other questions.
Kevin
