300 watt power pack should have 300 watt load.
You have 165 watt load.
Copy following link for general tips to get Malibu power pack to last longer.
http://waterheatertimer.org/Malibu-power-pack-stopped-working.html
Problem might be the photo eye.
http://waterheatertimer.org/images/Malibu-8100-9045-01-large.jpg
Rotate manual dial to ON position and see if lights turn ON.
Keep in mind the digital power pack has photoeye that is light sensitive, and must be exposed to dark light to activate.
For timed functions. Rotate manual dial until it points at timer. Press clock set function button, and use up-down buttons to set current time. Press timer ON button, and then use up-down to set ON timer. Then press timer OFF button , and use arrow keys to set OFF time.
This product has 1 year limited warranty, contrast with old-type analog power pack with 5-year warranty.
Malibu does not even post a manual on their site, which might have troubleshoot section to illuminate why your system has problem,
http://malibu.brinkmann.net/customer_service/owners_manuals.aspx
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
SOURCE: Malibu ML200RT low voltage power pack is not working
First check to make sure that you do not have more watts pulling than is recommended. If this is ok then pull both the red and black plastic pin from the timer and replace them then try. If neither of these solutions work you may have a problem at power source.
SOURCE: I currently have a 600 watt power pack w/timer on
20A circuit x 80% service factor =16amps continuous. 16amps x 120V = 1920 wats. Your total would be only 900 watts. I have assumed that since you have a 20A ground fault breaker that you have #12 ga copper conductors. If you had a considerable distance the 16 amps continuous would drop due to voltage drop and so the total wattage would also, but you're way below these levels.
SOURCE: Malibu 300-Watt Low Voltage Transformer ML300RTW Not Functioning
My power went off at my house. After it came by on how do I reset the transformer to come on automatically?
SOURCE: My Malibu 200 Watt Power
There is no fuse and no repair parts
I've been all over the Malibulights.com website looking for anything that might help the large number of people with Malibu questions. The website has very little information and no parts and the site offers no help except the following:
1) Malibu gets the customer money, and other people troubleshoot for their customers
2) When buying a power pack, the total bulb wattage on the line has to match the power pack wattage
10 - 20 watt bulbs = 200 Watt power pack
15 -20 watt bulbs = 300 Watt power pack
http://www.malibulights.com/guides_support/low_voltage_planning_guide/select_your_power_pack.aspx
If your power pack is oversized, it will burn out the bulbs and burn out the power pack
3) A power pack makes a humming noise when it has power >>> check your power source if power pack won't work >>> no other troubleshooting is offered
4) Replace burned out bulbs ASAP or the power pack burns out the other bulbs
5) Unplug power pack when working on bulbs [otherwise, the power pack burns out which is why people write fixya asking why their power pack won't work after replacing all their bulbs]
6) Nowhere on the Malibu site does it offer-or-explain burned out power packs or power packs that don't work, but they show plenty of new products for you to buy.
SOURCE: The timer feature of my Malibu 300 watt power pack
Unfortunately when the power pack stops working there is no solution.
Your power pack has electricity so that is not the problem.
The bulbs turn on, so the bulbs are ok.
That means the power pack has malfunctioned, and needs to be replaced.
I did find some tips to help folks preserve their power packs:
1) Match wattage of bulbs with wattage of power pack
-15 each X 20 watt bulbs = 300 watts, so install 300Watt power pack
2) Installing a 500W power pack on 300W of bulbs will burn out bulbs and power pack.
3) Replace bulbs as soon as they burn out or other bulbs will burn out and power pack will burn out.
4) When working on bulbs, unplug power pack or it may burn out.
Power pack should match total wattage of bulbs
10 - 20 watt bubs = 200 Watt power pack
10 - 15 watt bulbs = 300 Watt power pack
