Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
Posted on Nov 28, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do i take the tub out of the cabrio washer?
Anonymous
Level 2:
New Friend:
Greenhorn:
A rookie expert who has answered 20 questions on their first day.
  • Expert 79 Answers
  • Posted on Mar 20, 2013
Anonymous
Expert
Level 2:
New Friend:
Greenhorn:
Answers
79
Questions
5
Helped
169352
Points
102
Richard Roth
Level 3:
Top Expert:
  • Whirlpool Master 9,472 Answers
  • Posted on Nov 28, 2012
Richard Roth
Whirlpool Master
Level 3:
Top Expert:
Answers
9472
Questions
Helped
2627356
Points
28464
I have the complete service manual for the Cabrio washer. Go to
http://appliancecafe.com and click on the repair forum link on the top of the page, signup for the forum and then you will have access to the service manual area. Go to the washer section and the Cabrio service manual is the very last post. Let me know if you have any problems getting it.
1helpful
4answers
Whirlpool cabrio loud noise
Check your bearings. This post will show you most of what you need to know about your bearings:
http://www.squidoo.com/how-to-replace-bearings-in-a-whirlpool-cabrio-maytag-bravo-or-kenmore-oasis
Whirlpool Cabrio makes excessive noise during spin cycle
Your model has a bearing under the tub which is probably going bad and needs to be replaced. cabrio washer bearing replacement YouTube
6helpful
2answers
I have change stuck is washer making noise when washing. How do I get it out
If this is a Whirlpool Cabrio, it has two pumps. One is the drain pump and the other is a recirc pump. In most cases, loose change an other items end up in one of these pumps. The following link explains how to access and check the pump(s) on the washer for obstructions.
http://www.fixya.com/support/r4155097-checking_drain_pump_whirlpool_cabrio
If you have something stuck in the wash tub, you will need to remove the washplate in the center of the wash tub. Follow these steps:
1. Lift the washer top panel by locating the retaining clips in the seam along the front (about two inches in from each side). Use a putty knife to push in while lifting on the top panel to release.
NOTE: Its a good idea to tape the lid shut to prevent it from flying open when you lift the washer top.
2. Remove the wash tub ring. This is the plastic ring around the perimeter of the top of the wash tub. There are a series of release tabs around the tub that you can pry with a screwdriver.
NOTE: The washplate will not come out with the tub ring in place.
3. With the tub ring removed, pop the center post cap off the washplate. Locate the center nut and remove. Hold the washplate with one hand as you loosen to keep it from turning.
4. Lift the washplate out of the tub.
With the wash plate removed, you should easily be able to access anything stuck in the spin basket.
If you have any questions, or if this is NOT a Cabrio, please post back and let me know. I hope this helps you.
1helpful
My cabrio top load washer leaks from underneath during the wash cycle it not the draining hoses
there is the main tub seal that could be leaking and it is between the tub and transmission.
4helpful
Whirlpool Cabrio Washer- When draining, water leaks out of hole
probably rubber hose from tub to pump broke, access from back or bottom, (cabrios are open bottom) pump in rear. there is a recent bulletin about tub ring not channeling water from dispenser completely into tub
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
