Need User Manual for Whirlpool MagiCook 22 G model
SOURCE: MagiCook 22C not heating
Test the high voltage capacitor,the rectifier diode.or the magnetron. If all this are fine, test the control board.
The
diode and capacitors can br tested. The capacitor must be
alloweddischarge before testing, or you risk to get electrocuted, even
ifpower is off. Capacitors can get discharged by shorting their
twocontacts.
Before replacing the magnetron test also the control board.
Replace the magnetron if the checks and all of the high voltage component tests are good, but the unit still does not heat.
All locations, and description of this parts can be located using the diagram here: Counter top.
Parts must be tested to find out what is wrong.
Remember that microwaves are potentially dangerous devices if not repaired properly, the job must be done by a competent person.
A microwave energy leakage test must always be performed when the oven is serviced for any reason.
Regarding parts, contact the seller here to purchase parts. (here in UK).
SOURCE: I have a magicook 20G(galaxy). My problem is that
Did you get answer about it? I have same question :(
SOURCE: I am having a microwave
http://www.espares.co.uk/search/whirlpool/p/0/278?utm_source=google&utm_medium=cpc&utm_term=whirlpool&utm_campaign=Spares_Whirlpool
or log on to the
manufacturer's web site, whirlpool.com, I think you will be pleasantly surprised as
usually one is able to download, by model number, Customer
Instruction Manuals, and a list
of Dealers as required. Just Google the manufacturer's name and
follow the links. Make certain you are directed to the manufacturer's
web site as some search engines direct you to other sites and they
charge for the information that is normally free of charge. I
hope this helps.
I don't think there is a solution to aquiring a user manual as I have googled all international and national web sites and they bare all requesting a user manual.
Sorry
SOURCE: I purchased a Microwave from
Most major manufacturers supply manuals
online so if you were to log on to the manufacturer's web site, you
may be pleasantly surprised as usually, if available, one is able to
Instruction Manuals, Dealer
Network for spare part supplies as
required. The information is normally free of
charge. I hope this helps.
required.
charge.
I hope this helps.
or log on to the
I
hope this helps.
adsfgdhfdjhgk
