Question about Kenmore Elite 21086
Ice maker is stuck
Elite
  • 6 more comments
  • Stephen Schaefle Nov 28, 2012
    The bar is halfway up and I can feel the fingers just above the ice chambers. It's been in that position for a few days now. I've tried killing power to the fridge to see if it would recycle itself but no joy. I cleared out the ice as best I could but I'm wondering if I need to remove the icemaker altogether.
  • Richard Roth
    Richard Roth Nov 28, 2012
    OK, what is that model number?
    596.75523400
  • Richard Roth
    OK, lets do this. Manual Cycle Initiation The icemaker ejection cycle is initiated by the thermostat. If, however, the icemaker is not ejecting, it will be necessary to manually initiate an ice ejection cycle. After removing the front cover, turn the motor shaft (small gear) 1/2 turn in the counterclockwise direction. This will rotate the cam enough to transfer the hold switch and provide power to the motor. If the thermostat is closed at this time, the heater will likewise be energized and the icemaker will complete the cycle. After manual initiation, carefully feel the bottom of the mold. It should begin to heat. If it doesn't, either the thermostat has not yet closed or the heater is open. Before manually initiating a cycle, check the position of the ejector arm. Assuming the problem is in the icemaker, the position of the ejector arm will give you an indication of the failed component. If the ejector blades are still in the home position (9 o'clock) the thermostat is most likely at fault. If the ejector blades stopped between the 9 and 10 o'clock positions, the hold switch is most likely at fault. An ejector at the 4 o'clock position normally indicates an open heater. Any position other than the 9 or 4 o'clock positions may indicate motor problems or broken, stripped or missing parts in the housing. To begin harvest turn drive gear counterclockwise, do not use ejector blade to start cycle. Post back your results.
    I don't see a small gear. Only a big one with red letters saying not to turn it manually. Can you describe what I should be seeing a little better?
  • Richard Roth
    I'll tell ya what, if you go to my website athttp://appliancecafe.com and select the repair forum from the top of the page, signup for the forum, go to the service manual area, ice makers, and you can download the complete service manual for the whirlpool ice maker. Go to page 9 you will have the info I sent you along with the pictures and all. Let me know if you have a problem getting the manual.
    OK. By looking at the manual I could see where the gear was supposed to be - up and to the left of the large gear. Mine is covered by an unremoveable cover, so that meant I had to do what the red letters told me NOT to do - turn the big gear manually. I grasped it in my right hand and turned it clockwise (you said the small gear should go counterclockwise, so...) As soon as I did, the motor started turning the gear and I heard water go into the mold a few seconds later. Once that happened the metal arm fell to the down position. Problem solved, eh? Thanks for all your help!!
  • Richard Roth
    I'm glad I was able to help you.
    Top Expert:
  • Kenmore Master
  • 9,472 Answers
Could you please describe the problem you are having a little better?
Posted on Nov 28, 2012
Testimonial: "Good dialogue and a great appliance repair website with manuals!"
6ya staff
SOURCE:
What is the voltage and amperage that i would use to charge my jazzy select elite it did not come with charger
24 volt - 3 amp
Buy one SPECIFICALLY for it.
Jazzy Select Elite Parts - Jazzy Parts - All Mobility Brands - Mobility ...
https://www.monsterscooterparts.com/mobility/mobility-brands/jazzy/jazzy-select-elite
Items 1 - 72 of 72 - Order the Jazzy Select Elite Parts from Monster Scooter Parts, and know you ... Battery Charger Power Cord (IEC C13) for Mobility Scooters and ...
Amazon.com : 24V 3Amp Jazzy Select 6 Ultra Scooter Battery Charger ...
https://www.amazon.com/Jazzy-Select-Scooter-Battery-Charger/dp/B00CIZ1GW6 Rating: 4.5 - ‎42 reviews
Amazon.com : 24V 3Amp Jazzy Select 6 Ultra Scooter Battery Charger : General Use Batteries : Sports & Outdoors.
Pride Jazzy Select Elite and Jazzy Elite Battery Charger
https://atozwheelchairs.com/pride-jazzy-select-elite-and-jazzy-elite-battery-charger.html The Jazzy Select Elite and Jazzy Elite 6 Battery Charger is compatible with models with serial numbers beginning with JB3. It is an offboard charger that fully ...
Jazzy Select Elite Replacement Parts ' Battery Charger » Charger ...
https://www.southwestmedical.com > Replacement Parts > Pride Mobility
Battery Charger » Charger Assembly - Off-board, For S/n Begin With Jc1 replacement parts for the Jazzy Select Elite.
Pride Mobility Jazzy Select Elite Wheelchair and Mobility Chargers at ...
https://www.batteriesplus.com > Chargers > Wheelchair and Mobility > Pride Mobility Pride Mobility Jazzy Select Elite Wheelchair and Mobility Chargers from Batteries Plus Bulbs. Deep cycle chargers for electric power wheelchair and personal ...
Jazzy Select Elite and Jazzy Elite 6 Battery Charger - Care Motion
https://caremotion.com/.../pride-jazzy-select-elite-and-jazzy-elite-6-battery-charger US$105.00 - ‎In stock
A 24V 3AMP charger for for Pride Mobility Jazzy Select Elite and Jazzy Elite 6 powerchairs.
jazzy select elite charger Google Search
Aug 02, 2018 | Elite Health & Beauty
Tip
Top Shot Elite Set Up and Usage Guide by Activision Follow this link to the...
<b><u>Top Shot Elite Set Up and Usage Guide by Activision</u></b><br /> Follow this link to the Guide on <a href="http://www.facebook.com/ActivisionHunts?sk=app_2373072738#!/topic.php?uid=133041143393695&topic=331">Facebook.com/ActivisionHunts</a><br /> Also see the following <b>Expert Videos</b> to have the best gameplay experience with your <b>Top Shot Elite</b>:<br /> <a href="http://www.facebook.com/ActivisionHunts?sk=app_2373072738#!/video/video.php?v=10150089463307966">Top Shot Elite How To Video 1 - Introduction</a><br /> <a href="http://www.facebook.com/ActivisionHunts?sk=app_2373072738#!/video/video.php?v=10150089459077966">Top Shot Elite How To Video 2 - Syncing</a><br /> <a href="http://www.facebook.com/ActivisionHunts?sk=app_2373072738#!/video/video.php?v=10150089455422966">Top Shot Elite How To Video 3 - Calibration</a><br /> <a href="http://www.facebook.com/ActivisionHunts?sk=app_2373072738#!/video/video.php?v=10150089452377966">Top Shot Elite How To Video 4 - Dead Zones</a><br /> <a href="http://www.facebook.com/ActivisionHunts?sk=app_2373072738#!/video/video.php?v=10150089448732966">Top Shot Elite How To Video 5 - Red Lens</a><br /> <a href="http://www.facebook.com/ActivisionHunts?sk=app_2373072738#!/video/video.php?v=10150089445917966">Top Shot Elite How To Video 6 - Troubleshooting</a>
on Feb 17, 2011 | Video Game Consoles & Games
Kenmore elite 5 burner grill manual
Kenmore Gas Grills Manual - Sears
https://www.sears.com/search=kenmore%20gas%20grills%20manual Items 1 - 37 of 37 - Kenmore Elite 5-Burner Dual Fuel Gas Grill with Motorized ... Star Manufacturing Star - 848MA - Ultra-Max® 48 in Manual Gas Griddle.
Kenmore Elite 5-Burner Dual Fuel Gas Grill with Motorized Rotisserie Kit
https://www.kenmore.com/.../kenmore-elite-kenmore-elite-5-burner-stainless-steel-gas... The Kenmore Elite 5-Burner with Rotisserie Kit: A Reliable Cookout Staple Play host to the perfect outdoors party with ... Play host to the perfect outdoors party with your Kenmore dual fuel gas grill. ... Assembly, Minimal Assembly Required ...
[PDF]Owner's Manual - The Grill Services Corporation
www.grillservices.com/manual-downloads/720-0286.pdf Kenmore Elite Warranty ... Burners: 5 Years. Flame Tamers: 3 Years. Cast Iron Cooking Grids: 3 Years ... grill. The gas regulator assembly supplied with your gas.
Kenmore elite 5 burner grill manual Google Search
Jul 28, 2018 | Kenmore Grilling
Need owners manual for lowrance model# elite 4 hdi
here you go
[PDF]Mark-4 HDI & Elite-4 HDI - Lowrance
https://www.lowrance.com/.../Lowrance.../ELITE-4_HDI_OM_EN_988-10576-001_w....
Installation & Operation manual. Mark-4 HDI & Elite-4 HDI. Operation manual ... Lowrance Mark-4 & Elite-4 HDI ...... Selects the transducer model attached.
[PDF]Elite-4x HDI - Lowrance
www.lowrance.com/.../Lowrance.../ELITE-4X_HDI_OM_EN_988-10586-001_w.pdf Installation & Operation manual. Elite-4x HDI. Operation manual .... 4. Basic Operation ' Elite-4x HDI. Selecting Pages. To select a page, press the keypad in the direction of the desired page and ..... Selects the transducer model attached to ...
[PDF]Mark-4, Elite-4,5, 7,9 Operation Manual - Lowrance
https://www.lowrance.com/.../Lowrance.../MARK_ELITE_SERIES_CHIRP_OM_EN_98...
... Elite-7 & Elite-9. Operation manual ... NOTE:This manual covers Mark-4, Elite-4, Elite-5, Elite-7 and Elite-9 units. As a result ..... Selects the type of transducer model attached to your unit. ..... HDI 83/200kHz (Medium/High CHIRP. 83/200kHz ...
manual for lowrance model elite 4 hdi Google Search
Oct 21, 2017 | Lowrance Boating
How can I get a user manual for my Kenmore Elite 30 inch Electric slide in range with ribbon radiant elements model number 46804
Kenmore Elite Electric Slide In Range 30 in. 41053 - Sears
www.kenmore.com/kenmore-elite-30inch-slide...electric-range...
Kenmore
Rating: 3 - ‎30 votes
The slide-in Kenmore Elite range 41053 has a true convection oven for faster pre. ...Kenmore Elite 30" Slide-In Electric Range w/ Convection - Stainless Steel ... Owners manual - English (Warranty) .... I called SEARS repair to look at my range and the repairman told me that this range has flaws with the oven fan and there is ...
Kenmore Elite 30" Double-Oven Slide-In Electric Range w
www.kenmore.com/kenmore-elite-30inch...slide...electric/p-02...
Kenmore
Rating: 3.5 - ‎30 votes
The exciting Kenmore Elite double-oven slide-in range 4111 offers all the feature. ... Versatile cooktop options include a 12-inch triple-ring element, a 9-inch Turbo Boil Flex™ element, and a ... Owners manual - English (Warranty) .... Ovens are both conventional or can be set to convection, my first bake was a cheese cake.
Nov 28, 2015 | Kenmore Kitchen Ranges
I have a kenmore elite he3 smart heat quiet pak4 how much is a motor for this dryer
  1. Kenmore Elite He3 Parts - searspartsdirect.com‎
    Adwww.searspartsdirect.com/Kenmore-Parts‎rating for searspartsdirect.com
    Shop Today at Sears PartsDirect™. The Largest Appliance Parts Seller.
    Ratings:Shipping 9/10 - Website 9/10 - Selection 9/10 - Quality 9/10
Search Results
    MOTOR diagram for model # 41794130000 Kenmore-elite ...
    www.searspartsdirect.com/model-part/41794130000/0583/.../00004.html
    MOTOR Diagram and Parts List for KENMORE ELITE Dryer-Parts model # ... MOTORdiagram for model # 41794130000 Kenmore-elite-Parts Dryer-Parts (18).
    PUMP AND MOTOR PARTS Diagram & Parts List for Model ...
    www.searspartsdirect.com/model-part/11047789702/0583/.../00006.html
    PUMP AND MOTOR PARTS Diagram and Parts List for KENMORE ELITE ... ANDMOTOR PARTS diagram for model # 11047789702 Kenmore-elite-Parts ...
Nov 01, 2015 | Kenmore Dryers
Washing Machines Logo
248 people viewed this question
fordexpert
Harvey Mahal
Kristen Denison
Kristen Denison
Level 1 Expert
