How old is your iMac ? SOunds to me like it has been left on too long for too many years.. THese screen eventually burn in and then it's the end... Sorry.
1. First download and install Tuneup Utilities 2. Now click on Customize Windows -> Tuneup Styler 3. It'll open a new window. Click on "Boot Screen" link in left-side pane. 4. Now click on "Add -> Load Boot Screen From File..." option. 5. Select your boot screen file and click on "Install Boot Screen" button. 6. You can also create your own boot screens. To create new boot screen, click on "New Screen" button. It'll open a new window. Now click on "Search Local Drives" link and select the image. You can also set the image alignment, borders, background color and progress bar position. 7. Once you finish, click on "Save boot screen" link and provide a name to your boot screen. 8. You can even see the preview of the boot screen by clicking on "Show large preview" link or by clicking on the image in Preview pane: 9. That's it, your new boot screen is ready. You can apply it by clicking on "Install Boot Screen" button.
hi
Place the document or image into the scanner for scanning. A scanner with a paper feeder will only receive flat papers and photographs, but a flatbed scanner opens to accommodate books, fabrics and leaves along with flat papers. There is even a attachment for feeding photo slides into flatbed scanners.
Step 2
Start the scanning software. If the scanner does not engage the software automatically, press the "start" or "scan" button, or click the scanner icon on the computer screen to initialize the software.
Step 3
Activate the scan. Click the "file" menu and select "acquire," "import," or another practical choice that applies.
Step 4
Preview the item to be scanned. Most scanners have a preview option. This will show the scan area inside dotted lines. The lines can be moved with the mouse to relocate, enlarge or crop the scanning area.
Step 5
Set the resolution for images by number of dots per inch (dpi). For computer screen viewing, 100 dpi should suffice. Use 200 to 300 dpi for items to be printed.
Step 6
Use the appropriate setting for scanning black and white text. If the scanner does not show a preset for text, use "line art" or "black and white" at 300 dpi. Then use the optical character recognition (OCR) program to convert the image of the text into a file for word processi
Yes your printer will send and receive faxes.
1. Make sure:
• The printer is connected to a computer that is equipped with a fax modem.
• The computer is connected to a working phone line.
• Both the printer and the computer are turned on.
2 Load an original document facedown on the scanner glass.
Here is the manual, in case you don't have one
http://www.retrevo.com/d/ds/progress?doc=7d2128cd89431b0e3d4c2a1c31fa8fc4
3 From the desktop, double-click the Imaging Studio icon.
4 Click Fax.
5 Click Scan and send a fax.
6 Click Preview Now.
7 Click and drag the dotted line box to select a specific area of the preview image to fax.
8 Adjust the settings as needed.
9 Click Next.
10 Follow the instructions on the computer screen to complete the task.
Receiving a fax using the software
1 Make sure:
2 From the desktop, double-click the Imaging Studio icon.
3 Click Fax.
Sounds like you accidentally pressed the DISP button on the back (it manually turns the LCD screen on and off to save batteries). Turn the camera on and press the DISP button once. Hopefully that should fix it.
Hello Nick,
please purchase special mini DV tape for head cleaning. After a treatment with this tape you can check if there is an improvement with other tapes.
If you need more info please advice.
Arpi
