The date on the TV is 2007. Otherwise everything works fine. Interested in using the sleep mode, not normally found on universal remotes. can't seem to use buttons on side to access menu to do this, or can I?
It sounds that your remote control need cleaning. Visit the site linked below to know more. Details are given there about how to check and repair, clean etc to a remote control. Pull up older posts there. It will help you. Visit the site named 'Electro-help' for more details. Click this link. View it in "Timeslide" or "Flipcard" option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. You can also click the [Home] tab to the latest updates. It will make search easy. There are more than 1350 posts to different brand TVs now. Pull up older posts there.
SOURCE: FLM 3232 PROBLEM
the control board is out on all of your tv's very common problem the board new was 479.00 . part no 909 KSO GF321XA, do a internet search, you will see i am right, if interested i have one good used and i will accept offers, its easy to install would take 30 minutes with four screws and five wire harness plug ins. can do your self.
SOURCE: POLAROID 1511-TLXB LCD TV Remote Code for Verizon FiOS STB
I posted that as a point of information. I noted from searches that other people were having remote code problems w/that TV set. Code 0205 worked for me.
SOURCE: Polaroid TLX-04244B Remote wont work
5 Digit code is 15231
3 Digit code is 494
Hope that helps, took me about 4 hours to get that figured out!
SOURCE: my remote control for my polaroid tv wont change channels.
You may be able to program your cable box remote to control your TV in addition to your cable box. When they initially set up your cable box they probably left a pamphlet giving you instructions on how to program your remote. I'm not sure why you can't change the TV channels manually but this may give you a work-around.
