Vacuums Logo
Simon Ballantyne Posted on Nov 27, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Repairing contacts in Electrolux Z8240 handle
Wiper blade for powerhead in handle is broken - how to disassemble handle to repair?
  • soulmasterdw
    soulmasterdw Nov 21, 2015
    ok be4 read this these bits of info are for savvy people who know how to read inbetween lines and are safe rish takers......
    first could try bit of crc down some hole that leads to voltage rails and slide it heaps up and down hopefully gives it clean and also stops it getting oxodized to recreate fault
    con if had contact greese that will be all gone now and crc is flamable so if decent amout of spark canbe created by the rails could possbly catch fire but once crc drys the oil be left and be fine
    i squirt into running motors and get little bit fire and its algood
    just like cooking with high % alcohol be prepared
    u can open but.....
    its eatheir going to be the fidliyists peice of pain ever
    or ur going to have to brake somethink and figure out how to remake it to work as should
    or could try some magic
    dont properly open it but prize it open enough and have it in right place just sos can get to wiper contacts and force them back down with somethink that fits...
    if ur not used to metal bendint i sagest u go practice because its difference betweeen making esay or hard for urself
    theres odd way u bend metal sos makes contact and holds pressure down
    now the esayest and oddest thing of all would be get a dead/spare shaver lead or phone handset lead the ones that are coiled up find were the contacts are on the tube peice and fit the lead into that bit and unortodox fit
    need to check that the lead is rated good enough for use current voltage insulation etc
    and that its secure to hose
    dont wana short and have it take out the main board for vaccume
    this is ideas for people who understand electronics and mechanics and are enccentric enough to pull it off
    isnt for dummies unless ur on a jackarse mission
VacuumSpot
Level 2:
Novelist:
  • Expert 171 Answers
  • Posted on Dec 07, 2012
VacuumSpot
Expert
Level 2:
Novelist:
Answers
171
Questions
0
Helped
80026
Points
286
Hi There, Alec From VacuumSpot here. I work as a vacuum technician and unfortunately I am the bearer of bad news the handle is not really repairable. Even in warranty Electrolux allowed us to simply swap the hose over in favour of any repair. If you need to buy a new Z8240 hose the part number is 1131404541.
  • soulmasterdw
    can u drop some specs on the mcu board and the hose controller
    have no hose and wanting to see difficulty in making mi own controll unit and the mcu board on mine posibly dead
    already know has toshibia mcu but so much haxing required to figure out
5 Related Answers
Anonymous
  • Posted on Nov 15, 2008
SOURCE: Electrolux Z8240 model vacuum cleaner
Inside ,the dust collection container, there at the far end is a white cone shape (another filter). I think you may find this covered in lint etc and if you reach in with your hand you can just pull the stuff off. Happened to me around the two month mark and I THINK, so far, so good. My machine is now not switching off and flashing lights at me and the suction is back to fabulous. Found this information on another obsure website. You would think electrolux would mention it in their "Troubleshooting Guide" GOOD LUCK
Anonymous
  • 17 Answers
  • Posted on Feb 08, 2010
SOURCE: i have a bissell proheatX2. it has quit spraying
Here is how
eVacuumStore.com
  • 47 Answers
  • Posted on Apr 17, 2010
SOURCE: need Electrolux prolux Repair Guide
http://evacuumstore.com/s-1-electrolux.aspx?CategoryFilterID=0
Roger Potts
  • 694 Answers
  • Posted on Aug 22, 2010
SOURCE: Disassemble electrolux olympia one vacuum.
Before taking the machine apart, always check for clogs in the hose and power nozzle, full bag, and/or plugged hole under the bag. Suction/vacuum loss can also be caused by leaky or cracked hose, including the section in the power nozzle.<br /> The best way to check for clogs is simply drop a large marble in one end and let it roll through. To check for leaks in hose, hook to exhaust port, pour a small amount of liquid dish soap in other end of hose, lift high and turn on vacuum. Bubbles will appear at badly worn spots and cracks in hose.<br /> There is no need to pull out the motor, as their is no filter surrounding it, motor does not need lubrication, and the above check should result in locating the problem.<br /> Repair manuals are only available to Electrolux franchise owners as highly restricted software.
Anonymous
  • Posted on Nov 01, 2010
SOURCE: The clip that holds the EL5 powerhead to the wand has broken (again). How does one fix this?
i found this part online- search for part # via an exploded parts diagram of your specific unit (via google)
i ordered 5 of them because it always breaks or pops out.
this is a nice machine with crappy parts.
sorry :(
2helpful
2answers
I have good suction on the hose but none at the powerhead? Has New Belt & checked for clogs??
Have you checked the motor on the powerhead? It runs on a separate motor from the vacuum cleaner. Also make sure the belts in the powerhead are good. Hope this helps.
2answers
The powerhead on my Electrolux Epic 8000 has stopped working. It still vacuums up stuff, but the rotating brush doesn't work. The model number is N106M. How do I fix it? I've already pushed the reset...
Does it have a drive belt? if so, is it broken? Some vacuums have a switch that shuts off the beater bar if the handle is upright like when using the hose. This switch, if it exists on yours, could be stuck, out of adjustment or broken. Good luck.
Electrolux EL7055 powerhead not working
Have you tried testing the continuity in the hose, wand, and power nozzle? You can also try putting the hose directly in to the power nozzle. If you still need help with you electrolux vacuum try contacting evacuumstore.com
Nov 17, 2013 • Vacuums
Bad sumo board
HI There,
I have replaced quite a number of SUMO boards on the Electrolux Twin Clean Vacuums. We have them in our online store vacuumspot.com.au
I am a little unsure from your question if you are looking to buy one or hoping to repair the board itself. If you are looking to buy this Sumo Board (part number 2193235021) or any other Electrolux Z8240 Spares we can certainly help you there.
However as far as I am aware the board is not realistically possible to repair so if that is what you wanted to do I think you are out of luck.
Hope this at least clears things up a little.
Regards
Alec
1helpful
Remove bottom of electrolux prolux upright vacuum. Hose is clogged.
You shouldn't have to remove disassemble the powerhead.
Lay vacuum on it's front. Between the tank and the powerhead is a black flex hose. Pull the end straight out from the powerhead. Then unscrew the tube from the tank using a clockwise turn. Remove the tube and visually check for clogs and splits. Clear or replace as needed.
If there's a clog in the powerhead behind the brush, this can be cleared using a wooden spoon handle or similar object.
If there's no clog in either place, there's a couple other possibilities. First, turn the vacuum back upright, open the hose flap, turn vacuum on, and place hand over opening to check for suction.
If there's a lack of suction, the bag needs replaced, the afterfilter beneath the bag needs cleaned, or the motor needs replaced.
If there is suction, put a coin in the opening inside the port and to the right as you're viewing the front of the vacuum. The coin should drop to the floor. A clog in thes section is unusual, but can happen.
If there is still no suction, take the vacuum to the nearest authorized Aerus Electrolux store for free diagnosis.
http://www.aerushome.com/storelocator/
5helpful
Power head and wand has no power. Unit is less than 4 month old.
Hi, I had the same problem with mine and found that if you plug the power head directly into the handpiece (bypassing the telescopic wand) and it worked only proved the problem is in the telescopic wand. The problem as I found was a broken terminal in the end that connects to the powerhead (female socket). As it is a non repairable part means replacement at $100AUS I have had my machine for 3 years and in this time have replaced the both powerhead once and the wand twice within 2 years of owning the machine. The wand has now gone faulty again 4 months after replacing it and consequently Electrolux only warranty spares for 3 months which I think is poor! Its a great machine but a little too delicate even if it is only used for domestic operations once a fortnight! I paid $700 for my Oxy3 3 years ago and wont be buying another Electrolux product due to poor service (customer and product):((
Where to buy t joint for electolux vacuume EL7020 powerhead?
If you still have your receipt i would recommend to contact electrolux at 800 896 9756 you have a 2 year waranty so they should be able to either replace your power head or refer you to a service station that can repair it
3answers
I need a new hose for my Electrolux central vac
Do you need a new powerhead too or only the hose? If you need a new powerhead than I would recommend looking at the Imperium Pro Elite Attachment set. It is an excellent quality powerhead and hose. If you only need a new hose than you will need to contact the Aerus because they will be probably be the only company who can sell you a hose that wil be compatible with your powerhead. Their website is http://www.aerusonline.com/products/
Electrolux Z8240 Cyclonic Bagless Vacuum Cleaner
Be sure to check the hose , wands and power brush for obstructions as well.
If there's a burning hair electrical odor then it might be toast.
i despise bagless vac's as they always wind up being more maintenance and expence then bagged vac's.
Good Luck and let me know what you find out.
Oct 08, 2008 • Vacuums
2answers
Whispertone powerhead handle release replacement
Use a flat blade, it just prys off, a new on will press on.
Top Electrolux Vacuums Experts
eVacuumStore.com
Mike Cairns
Mike Cairns
Kolbrun...
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
