This just started happening, not sure why as nothing as changed with the dehumidifier. Instead of the water tray collecting water, the water is leaking out into the floor or collecting somewhere inside the machine and the water isnt' making it into the tray.
Mine is doing the same thing. The bucket is dry and the floor is flooded, so it is not an inability to condense, and it is not that the bucket has overflowed, and the bucket does not have a leak. It had been working great and then this suddenly started happening, it's as if the water is not flowing along the proper route and instead is gathering behind the bucket.
SOURCE: Kenmore 54501 Dehumidifier no water in bucket
may have lost ref charge check name plate for type of ref with 12 and 22 cost of gas cost proh. check tubing in rear should be ice cold to gather condensate if not probably lost gas
SOURCE: My 54351 dehumidifier runs for hours and doesn't collect much wat
I hope someone answers this because I'm having the same problem. Mine is about 4 years old. I thought it was my filthy filter but cleaning didn't change the problem.
SOURCE: I have a Kenmore 50 pint dehumidifier Model 580.54501400
It looks like it is simple to get the filter out but we are finding it to be imposible. How can we take it out. It doesn't just pull down.
SOURCE: Our "auto shut off" light
I believe on this model there is a water collection container. If you remove it & look up underneath, you will see a hose or outlet for the water. Take a screwdriver & push it up & squiggle it around in the outlet. If water starts to pore out, you've solved the problem. Good luck!
There
are many reasons why a dehumidifier will not work or collect water.
Here
is a tip that I wrote to help people to figure out what is going
wrong with their dehumidifier
Dehumidifier
is running but no water is in bucket
heatman101
There
Here
Dehumidifier
heatman101
