SOURCE: WHen I touch contacts, dial or menu nothing
try and reset the fone's calibration.. go to settings and in their check phone settings u will find a thingy called calibration select it and follow instructions...
SOURCE: my samsung s3600 was not
If the code you have applied is a master reset code then there will be no way to retrieve your numbers, unless they were saved on the sim, check that the phonebook is set to 'View SIM Contacts' by Address book > Menu key > More > Settings > Memory in use > View contacts from...
It is often set to only look on the phone as default.
