Goodman GMS90703BXA Heater Logo
chris rocha Posted on Feb 23, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
In heat mode but heat strips don't come on and the air handler fan dose not turn off
I tried to turn heat on but heat strips don't come on so i checked voltage got's power going to the sequerncer so i went to the stat and turned the stat off but it would not shut off i unplugged the wires to the stat and the air handler keeped running would not turn off
Thomas Woodburn
Level 3:
  • Goodman Master 2,638 Answers
  • Posted on Feb 24, 2018
Thomas Woodburn
Goodman Master
Level 3:
Answers
2638
Questions
Helped
1251926
Points
7008
Keep in mind that you need high and low voltage at your sequencer to bring your heat on. Or any relay for that matter, unless a high voltage coil, the 24 volts energizes or closes the circuit therefore bringing on the load.
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Andy
Level 3:
Loyalty:
Visited the website for 30 consecutive days.
  • Master 572 Answers
  • Posted on Feb 23, 2018
Andy
Master
Level 3:
Loyalty:
Answers
572
Questions
0
Helped
209745
Points
1498
Maybe a bad sequencer.unplugged wire from sequencer and see it unit shut off .Sequencer is typically a relay
5 Related Answers
Anonymous
  • 1420 Answers
  • Posted on Nov 21, 2008
SOURCE: installing new furnace with two zones
You will need a control to operate motorized zone dampers. In the ductwork, you will install a damper in each line going into the area you want zoned. If you have air conditioning you will also require a barometric relief damper that allows air to pass thru the ductwork and not restrict air over your A/C coil. Common controls are made by Honeywell and EWC.
If you already have the control module, you will run two or three (low voltage) wires from each motorized damper back to the control. Your thermostat wires (also low voltage) will run from each thermostat to the control module and connect to a zone relay. Match each zone by number. You will need to run power to the control module that will provide power to the thermostats as well as the motorized damper. Check on the reverse side of the control module and/or check on the web to find the wiring diagram.
Lou Barta
  • 189 Answers
  • Posted on Apr 29, 2009
SOURCE: ELECTRIC HEAT STAYING ON IN COOL MODE
Disconnect the white wire from the "thermostat". If the strips stay on its your thermostat wires.
Anonymous
  • 89 Answers
  • Posted on Oct 08, 2009
SOURCE: GMPN 100-4 furnace. Blower motor runs when not calling for heat.
The board is bad. The unit thinks a flame is present, so it tells the blower to come on. Replace the board.
Anonymous
  • 767 Answers
  • Posted on Dec 20, 2009
SOURCE: goodman 075-3 fan runs but no voltage going to igniter
One thing you can checkmis the continuity through the ignitor itself if you have continutity through that there is also some safeties it has to go through but the board is where the voltage is supplied for the ignitor. I would check the high limit and the roll out before condeming the board.
Anonymous
  • 455 Answers
  • Posted on Oct 05, 2010
SOURCE: I have a Goodman AR36-1 air handler. when I turn
Hello Your motor is shutting of thermal overload because of an internal problem.New motor time,Pull it and match it up the info is on the side of the motor.
Where can I get a schematic for a Coleman 3500A816 air handler?
With some units you must set thermostat to fan on to get the fan to run in heat mode.. or it could be a bad motor or fan relay . Generally in electric heat units one side of heater is always live then the sequencer turns heater on when thermo calls for heat.
What cause 3 amp fuse to keep blowing when power in turn on goodman air handler
The 3 amp fuse is in the red low voltage (24 volt) thermostat wire
and only gets power when the thermostat is set to turn on heat or a/c It should be connected to the red wire from the thermostat
HKR-10C FURNACE BLOWER WONT KICK ON
if you have change the thermostat it has to have the option for electric heat the thermostat has o turn the fan on in heat mode on air handlers
1helpful
HE heat pump won't talk with old air handler?
The fact is, the air handler supplies the voltage, blower, and electric heat. In order for the heat pump to work correctly, the wiring from the thermostat and heat pump need to be hooked up right to the air handler. The thermostat is what tells which component to come on. If the fan stops, but the condenser keeps going, you either have a faulty fan relay on the air handler, faulty thermostat or wiring, faulty wiring at the heat pump, or the contacts on the new unit are sticking, which is highly doubtful considering it is working now. I hope I have helped you understand this a little more. Good luck and don't let them push you around, get someone that knows what they are looking at.
1helpful
WIRING THE THERMOSTAT TO AC UNIT THEN FROM THE UNIT TO HANDLER
Generally, you would go from the thermostat to the air handler, and then, from the air handler to the outdoor unit. I don't know if you have a heat pump or not, so I will give you a simple diagram and you can contact me if you need more.
Thermostat : Y G R W and sometimes C
Air handler: Y G R W and C
Outdoor unit: two wires connecting to the contactor ( not heat pump)
Thermostat; Y--------------Y(air handler cooling)------------------one side of contactor, outdoor unit
G-------------G (air handler, fan)
R--------------R (air handler ,hot)
W-------------W (air handler, heat)
C--------------C (air handler, common)------------other side of contactor, outdoor unit
This is a typical wiring diagram. Just contact me if you have something different. Hope this helps. Stay cool. mark
1helpful
2answers
I just installed strip heat Rheem RXBH-1724A10J 10KW 208/240/1/60 into Rheem 14AJM36A01, RHPNHM3624JC, 3 Ton 16 SEER Air Conditioner Split System W/ GE's Variable Speed thermostat Pro 701 and it ran up...
This will help you.
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thank you for using fixya have a nice day:-)
1helpful
2answers
My air handler comes on ,not the outside unit when my thermostat is in the off position even if i turn the thermostat down to 50 and have it turned off the air handler comes on for about 5 to 10 minutes...
If you have a standard thermostat the fan switch is for the air handler only. It completely over rides the thermostat for most settings. Now lets see this is what I'd expect:
fan switch on Indoor fan runs all time
Fan switch auto Indoor fan only runs when thermostat is set to cool or heat and the thermostat is turned up above room temp for heat or below room temp for cooling. In both of these modes the furnace blower comes on and stays on til the room temperature is satisfied. The outdoor unit only comes on for AC the out door unit will not come on for heat or the "on" setting on the thermostat. See exception 1 & 2 below...
Exception 1- (in a heat pump the out door unit runs in both heat and cool mode unless it has emergency heat turned on then it will not come on outside in the heat mode, and depending on the type of heat pump and furnace or air handler it is). A heat pump thermostat usually has "backup heat" and an "emergency heat" setting switch on the thermostat.
Exception 2 - On some thermostats they are made to cycle on the heat if the temperature reaches a preset temp (around 50'f usually but definitely by 40'f). This mode prevents freezing when if instance the homeowner is away or while the home is under construction. In this mode the fan inside can run but the heat usually comes on with it.
Exception3 - On some electric furnaces the heating strips may be individually controlled and thus not all come on at one time. This may give the feel of no heat especially if the room is cold.
Now there may be other exceptions but Ive tried to give you a heads up on some of the most common ones.
If you need more help please post more specifics about your unit/system as to for sure what switches are set to what setting and what is happening with each. My first though was that maybe your system is OK and you needed to know if the thermostat was working properly.
If this helpd you understand your problem would you please give me as hifgh a mark as you can. Thnaks for using fixya and good luck.
Top Goodman Heating & Cooling Experts
Paul Carew
Mike Cairns
Mike Cairns
Jay Finke
Jay Finke
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
