SOURCE: 2004 Mercury Mountaineer Problem...wont turn over
just be liitle more specificc please do you hear any noise when you try to start it? like a click or something?
SOURCE: 2001 Mercury Mountaineer won't start
Have a load test done on the battery. If it checks out good, take a voltmeter to the battery and have an assistant rotate the engine. If you see more than a 2 volt drop when the car is being started, the starter is heading south.
SOURCE: 2004 Mercury Mountaineer Emergency Brake Adjustment
Greetings larslabs,
My name is Dennis and I can assist you to finding your parking brake adjustment location.
1) the adjustment is located so that you have to remove your center console floor finish panel (this is the drink holder).
2) raise your parking brake lever and gently pry the plastic tabs from the center console.
3) Once you can see the park brake lever you will see a nut that is turned to adjust the lever so that it has 5 clicks when it is applied.
Glad to be of assistance and thank you for using FixYa. Please rate the solution because I can learn from your rating (and it keeps my rating up to date). Thank you, Dennis
SOURCE: In 97 mercury mountaineer, how to turn off "check engine" light
Go to the local parts store, have them check the codes (they will do this for free usually). It will tell you what sensor needs to be checked/replaced. Once the part is replaced, it will clear on its own. They can also reset the code, but it will come back if the trouble persists.
what does this code mean B 1676 for 2004 mercury mountaineer
When i go to roll the motor over I get nothing, no clicking, no nothing.
