Question about Husqvarna Garden
Hi, I have a Husqvarna chain saw 345e EPAII. When i push the switch down to stop it, it doesn't. I removed the cover and a saw a wire (female connection)disconnected, but I don't see where thi
  • Rodrigue Potvin Nov 28, 2012
    Doea somebody have an idea where to connect this wire
  • Rodrigue Potvin Jan 21, 2013
    Thank you for help it's k now
  • Husqvarna Master
  • 1,807 Answers
Http://www.husqvarna.com/ddoc/HUSI/HUSI2001_AAaa/HUSI2001_AAaa__1062518-63.pdf
Section G of the ipl, shows the metal tang on the on off switch where it clips to.
Posted on Jan 19, 2013
    Thank you very much for the info. It is ok now
6ya staff
SOURCE:
Jay Unwin
SOURCE: husqvarna chain saw oiler
My Husky 36 did this. The oil pump drive gear was stripped and had to be replace. It's located under the flywheel/sprocket so you have to pull that. I couldn't find info on how to do that so had a local shop repair it for $70! Parts are cheap, labor is not.
Posted on Nov 11, 2008
Savu Mihai
  • 211 Answers
SOURCE: husqvarna chain saw, model 455 will not oil properly bar and chai
hi cindilou50
check the oil filter from the oil tank,the oil line ,the worm gear and the oiler under the clutch.Clean the ways where the oil goes with compresed air.(after you fill out the oil tank)Also check the oil hose.
best regards savumihai71
Posted on Dec 01, 2008
drallim
  • 4088 Answers
SOURCE: Husqvarna 359 leaking chain oil
Remove the sprocket cover, bar, and chain. Find area where oil is discharged from case--is any part of the rubber seal damaged? Next, use compressed air to clean sawdust and dirt from oiler ports in rear of bar as well as the chain slot. Are you using motor oil instead of bar oil? Make sure there is nothing to prevent bar from making close contact with oiler port in case. Reassemble all parts and adjust chain tension.
Posted on Jul 08, 2009
dontbother10
dontbother10
  • 2220 Answers
SOURCE: magneto to flywheel gap for Husqvarna 455 Chain Saw
Ignition module gap
Place a business or index card between the fly wheel and coil, rotate until the magnetic attraction pulls everything tight together. Tighten the coil screws, rotate the flywheel until the attraction eases and remove the card. Ensure nothing contacts when flywheel is rotated.
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Posted on Mar 22, 2010
tkaczyk
SOURCE: I have a Husqvarna 345e chainsaw. Can't get the cover back on.
That metal band you see which is preventing you from putting on the cover is part of the chain break mechanism. You were suppose to disengage the break before taking off the cover (I did the same thing). To get it back together you need to disengage the break by a tricky procedure and that will make the band diameter larger so it fits over the clutch. To force the band open, you need to first place the cover over the two bolts that hold the bar. As you already know, the back of the cover will not be able to fit over the clutch. Now in this angled position, bend (force) the break lever down (gray thing on top) until you can force together the sproket in the cover onto the mating pastic fitting built into the break lever. Now you can use the break lever to force down the internal spring and open the metal band. That will expand the stainless steel band and it will fit around the clutch. If you now push down on the back of the cover it will snap in over the clutch. Once you see how it is done, it is not so hard, but it is tricky because you are forcing some of the parts slightly out of position to get it back together. .
Posted on Sep 19, 2010
Kill switch on husqvarna 350 doesn't work
call your local or home repair shop/do not kill the motor by choking it out. also you may just have a wire come loose.
Oct 26, 2012 | Husqvarna Garden
Electrical wire?
Because of the simplicity of the ignition system, there really is no diagram necessary. Husqvarna uses a simple two-wire harness in that unit (e.g., p/n 544 08 28-01) that has two female quick-connects at one end and one female quick-connect and a ring terminal at the other end.
The end with the ring connector is the magneto end. The female quick-connect there attaches to the magneto primary circuit control terminal, and the ring terminal there is secured under the head of one of the two magneto armature mounting screws.
The opposite end of the harness goes to the ON/OFF switch on the case side near the handle. This switch is a simple single-pole/single-throw switch that allows the engine to run when in its open position, and kills the engine when in its closed position. The engine shut-down occurs through the effective action of grounding the magneto control terminal to the magneto armature frame, as accomplished through the circuit through the ON/OFF switch when that switch is closed.
To identify the armature, harness and switch for your saw, go to the Husqvarna Manuals Download Page for your saw, identify the list by the build date of your saw, and download the desired list. (I like the 2009-02 version as it has the sections identified and bookmarked, but be sure you ID the correct parts for your saw. It might help to DL your manual as well as the 2009-02 version for reference purposes.)
The armature and harness will be found on the Ignition / Flywheel page (items 7 & 8, respectively), and the switch will be found on the Air Filter / Intake / Carb and Air Purge / On-Off Switch pages, as item 9 (e.g., p/n 504 00 34-01, includes retainer bail).
If you are getting no spark from the plug wire when cranking the engine with the ON/OFF switch in its ON position, the problem must be in one of three places -- the magneto or its mounting, the harness, or the switch. A short between the magneto control terminal and the magneto armature will kill the spark, as will any short between the two wires in the harness. Similarly, an ON/OFF switch that fails to open (internally) will have the same effect as leaving the switch set to its OFF position.
If the engine will not stop when the ON/OFF switch is moved to its OFF position, an open magneto circuit is indicated. This can be due to a broken wire in the harness, a loose or corroded connection of the grounding (control) wire to the armature frame, a break in the magneto primary circuit to the control terminal, a loose or disconnected wire at the ON/OFF switch, or an ON/OFF switch that fails to close (internally).
While broken or shorted harness wires are easily repaired without replacement, any magneto or switch failures will usually require replacement of the failed component.
Jul 21, 2012 | Husqvarna 450 e-series 18" Chain Saw
Cover won't go on.round metal strip won't fit on round spindle that turns chain.E-235.Do I need the break bar?It doesn't line up either. DB
Sounds like the chain brake was set when you took the cover off. You need to disengage the chain brake (release it) so the round spindle will fit inside. Look for the two parts (one on cover, one on saw) that match up at the base of the chain brake. You won't be able to fit the whole cover on, but if you can line up where the metal triangular gear engages the chain brake, you can give it a snap to disengage it. What I have done in the past is to line up the two parts and push down on the top of the cover where they meet so as much of the gear is in the chain brake release as possible ( I put a knee on it ) and then give a snap to release it. Be careful though, because the cover part is plastic and you don't want to strip that part of the chain brake assembly. Good luck.
Sep 04, 2011 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
How do you set the chain tension on a 345e?
The E version is tooless, so flip out the wing in the centre of the big cover fixing nut,slacken the nut off half a turn, now turn the knurled adjuster in the side cover, down to tighten, up to slacken, there are many schools of thought about the correct tention of the chain, but basically the chain should sit snuggly all round the guide bar, and with a gloved hand pull manually around the bar with out too much force, it should never sag on the bottom of the guide bar.
Apr 27, 2011 | Husqvarna Chain Saw 20" Bar
Husqvarna 345e
I have a model 435 Husky that had the same hard-to-start problem--warranty service replaced the carburetor and it seems to work ok now. The chain that continues to turn can be fixed by turning the idle-speed screw (not the H or L jet screws) CCW a small amount until it can be accelerated then dropped back to idle to quit driving the chain. Hope this helps!
Apr 05, 2010 | Husqvarna 450 e-series 18" Chain Saw
Magneto to flywheel gap for Husqvarna 455 Chain Saw
Ignition module gap
Lou
Mar 22, 2010 | Husqvarna , No.455 Rancher, 20" Gas -...
I need to replace the chain sproket on my Hsuqvarna 345e chain sa
It has an out board clutch, please view this it is essentially the same.
R² Drive Link Outboard Clutch by Drivelink.blogspot.com
http://www.youtube.com/watch?v=cdqkIuVNUQc
  1. Check the IPL for your saw to see if any special tools are needed.
  2. There are metal piston stops available, when square (almost never) with the piston top these work well, if not square they have been known to punch through the piston. I suggest a length of starter cord or nylon rope be used instead of the piston stop (retain 6" ± so you can remove it). Make sure the piston is near the top of the cylinder before feeding the cord or it can fall through the exhaust port and damage the piston as it rises.
  3. Everyone I have ever removed had a left handed thread (tighten it to loosen it).
    Let us know how it worked for you.
IPL and operator's manual download
HusqvarnaUSA.com
http://www.husqvarna.com/us/homeowner/support/download-manuals/
Enter the 3 digit model number (no XPs, Es, just the numbers)
Serial number decode – useful when downloading IPLs and Manuals
06 1500198
06 = year produced – 2006 (single digit before 2000)
15 = week produced - March
00198 = 198th unit Husky produced that week
You may find detail B beneficial. HTH
Lou
Dec 17, 2009 | Husqvarna Forest & Garden No.967012396 345...
Take the chain off a 450 husqvarna
Pages 17 & 18 should help answer your question.
http://weborder.husqvarna.com/order_static/doc/HOUS/HOUS2008/HOUS2008_1151081-96.pdf (This may not be your saw)
Loosen the tension adjuster, remove the clutch cover, (engine to left) pull the bar off the adjustment pin then push it left against the clutch cover bolt. Remove the chain from the chain groove, remove the bar, the chain can now be removed.
You can download the correct Operator's Manual and IPL here:
HusqvarnaUSA.com
06 1500198
HTH
Lou
Dec 16, 2009 | Husqvarna 450 e-series 18" Chain Saw
Chain oiler stop working
remove side cover,bar & chain.ther is an ob long channel above the bar mounting studs that lines up w/the small holes near the edge of the bar,thats where the oil comes out.clean everything.sawdust gets packed in the holes & stops the oil flow.
Sep 22, 2009 | Husqvarna Chain Saw 20" Bar
Garden Logo
121 people viewed this question
Top Husqvarna Garden Experts
Marvin
Marvin
dannydoesita
Wayne McNeil
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
