Maytag Neptune MDE5500AY Electric Dryer Logo
Posted on Jan 10, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have maytag neptune 5500- shows error code 88
Anonymous
Level 2:
  • Expert 40 Answers
  • Posted on Oct 03, 2009
Anonymous
Expert
Level 2:
Answers
40
Questions
0
Helped
13376
Points
110
When the 88 displays, put a heating pad over the display - it will be ready in just a few minutes. Sounds crazy, but it works every time.
  • Anonymous Dec 18, 2011
    Thank you so much. Still worked like a charm. It took about 30 minutes of the heating pad on the display, while the dryer was unplugged.
Error code FL-maytag neptune front load washer won't lock
replace door latch (fl = faulty latch ) good luck APPLIANCES R EN
What does the code od mean?
The "od" code appears when you must open the washer door. The Maytag Neptune washer requires that you open the door between cycles.
Read more: Maytag Neptune Washer Error Codes ' eHow.com http://www.ehow.com/list_7170826_maytag-neptune-washer-error-codes.html#ixzz2GZKry68n
1helpful
Maytag washer Model# Mle19PDDGW showing error code D11 whats wrong
D11 is a motor speed error .
is the inner drum turning under power or not?
The code F25 shows up
Are you sure about that error code? My Maytag Neptune manual does not show any F error codes.
My Maytag Neptune dryer is showing an error code of 88. I have reset the circuit board, reset the dryer, but it wont turn on. Any help is appreciated.
Who ever posted put a heating pad on the display THANK YOU i put my wife's blow dryer on the back of the display and in 5 minutes its was working again THANKS AGAIN
2helpful
Neptune FAV6800AW Top Load Washer: My Neptune washer is showing error code dc..Once i...
See this post Clutch Fix if you want to DIY I will help you.
Post back if you have questions……..Rich
Error code of "dc" on my TL Maytag Neptune
If your machine is FAV6800AW or FAV9800AW the dc/UC errors are caused by a clutch malfunction. Your machine is shutting down with those errors so your Tub Displacement Sensor is working as designed.
Fix the Clutch malfunction and you can wash a single sock or a load of blue jeans and you will not take the dc or UC unbalance errors. See this post for the fix.
Post back if you have questions or need help.
Rich
1helpful
Won't start. Light are lit, but the 'start' button does nothing.
If the display shows an '88' then place a heating pad over the display. In a few minutes the '88' code will clear, and the dryer will work. Sounds crazy, but it works for me every time.
Top Maytag Dryers Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
