I have had this TV for 5 years or so but its not used much until now and the colour and sharpness of the picture is not at all good. I have used all sorts of setting but the best is Movie but it is still not sharp. I have a DVD player and a BT box attached. I have to change the settings depending on what is on.
SOURCE: BEST PICTURE SETTINGS FOR SAMSUNG 5044
Try this.... First, go into picture menu and reset it. Next turn contrast all the way up. Turn the sharpness all the way down. Make sure the tint is in the middle. Adjust brightnesses accordingly. If that don't work, just drop me a line and i will explain more
Best regards
CircuitCity
SOURCE: samsung tv settings
Freeview Built-in Tuner
Picture Mode: Standard
Contrast: 85
Brightness: 53
Sharpness: 25
Colour: 45
Tint: 50/50 (Greyed Out)
Colour Tone: Cool1
Detailed Settings:
Black Adjust: High
Dynamic Contrast: Off
Gamma: 0
Edge Enhancement: On
White Balance:
R-Offset: 17
G-Offset: 15
B-Offset: 11
R-Gain: 7
G-Gain: 14
B-Gain: 30
Backlight: 10
Digital NR (Noise Reduction): Auto
Active Colour: Off (Greyed Out)
DNIe: On
Movie Plus: On
Sound Mode: Music
SRS TX XT: On
Game Mode: Off
Energy Saving: Off
SOURCE: Modified Picture Settings Reset Each Time TV Is Turned Off/On
Your TV may have been put into shop
mode or demo mode.
How to get out of "Shop
Mode"
1. Press [Source] to get to the Air or
Cable input on the TV or TV remote
2. Press [Volume +] once on the TV itself
(not the remote)
Next step must be completed while
the volume bar is still on screen
3. Press and hold [Menu] on the TV itself
(not the remote) for about 7 seconds
If the screen
flashes "Dynamic Mode", the process worked
4. Finally check whether the Picture Mode
is "Shop Mode" or not after passing "INFO" on Remote Control. If picture mode is still in “Shop Mode” try the
alternative way below
Alternative Method
Press [Source] on TV remote to get
to the AIR or CABLE input
Press [Menu]
Press [Down Arrow] to highlight
SETUP and press [Enter]
Press [Enter] again on PLUG AND
PLAY
Wait 10 seconds
Press [Enter] to select ENGLISH (or
choose an alternative language
Press [Right Arrow] to highlight
HOME and press [Enter]
Press [Menu] repeatedly until you
see the message ENJOY YOUR WATCHING
Confirm you are out of shop mode by
pressing [Info] on the TV remote
SOURCE: best tv settings for samsung LE40A457
Best is kind of subjective since each person's eyes are different. If you are looking for a bright and vivid picture, you can go to the picture mode and change it to that setting. Usually it is called something like "Vivid" or "Dynamic." Besides that, it is all user preference. Most people prefer to just use the factory default settings.
SOURCE: I want to know the ideal picture settings for my
There are as you know factory presets to choose from in the user menu.. Your eyes will tell you what you like. The only other way to get a killer picture is to have the TV Calibrated by a good ISF Calibrator.
