After changing fuses and bulbs my rear running lights wont work
Are the side markers and license bulbs working?
I’m happy to assist further over the phone at https://www.6ya.com/expert/jeremy_d728a59f986299fa
SOURCE: Both 2003 oddyssey brake lights dont work High
clean bulbs socket out using the electronic spray cleaner for electrical connectors.
SOURCE: reverse light dont work
On the side of your transmission will be a switch with several wires coming out of it. This is your reverse switch that turns on your reverse lights and most likely needs to be replaced
SOURCE: How do you change the rear window brake light bulb on a 93 Honda
unscrew the case from around the light pull the case off and then youll have access to the bulb take the bulb out usually turns counter clockwise replace with new one reverse the process.
SOURCE: my passenger side low beam headlight wont work
what kinda car? doubt its a relay probably bad wire
voltage check wires
