Revent ovens, How do I calibrate a revent oven temp and how do I adjust the temp reader
SOURCE: maytag oven calibration
Maytag single built in oven model cwe9000bcb beeps intermittenly. Reset stops for about 1 minute. Two control panel boards replaced since 2002 with same problem. Can it be fixed?
SOURCE: Oven temperature only gets to within 20-25 degrees of temp. set
next to last page in your manual
Adjusting Oven Temperature
Oven temperature has been factory calibrated and tested. If
oven consistently over or under cooks food, adjust thermostat.
Oven temperature can be increased or decreased 35°F. To
avoid over adjusting oven, move temperature 5°F each time.
1. Push BAKE pad.
2. Press + pad until an oven temperature greater than 500°F
shows in display.
3. Immediately push and hold, approximately 5 seconds,
BAKE button until “00” appears.
4. Press + or - arrow pad to adjust oven temperature.
• To increase oven temperature (for a hotter oven), Press
pad until a positive number appears in display.
• To decrease oven temperature (for a cooler oven),
Press pad until a negative number appears in display.
5. Press OVEN CANCEL pad to save adjustment.
• Setting is saved if power fails or is disconnected.
heres a link to the entire manual if needed
http://shop.amana.com/assets/pdfs/literature/32103601.PDF
SOURCE: magic chef manual
You can download it here but you need the right model #.
http://shared.whirlpoolcorp.com/product_literature/search.jsp?siteCd=MCF
As for the temp adjust it is best if you get an repair man out to do that.
Good Luck
SOURCE: Oven will not achieve setpoint temperature.
You may not need anything. Most people test their oven with a dial type oven thermometer. They are slow to react and often not very accurate. When I test an oven or install a new thermostat, I use a digital thermometer with a remote temperature probe, hanging from the center of the oven, which shows the temp in tenths of a degree. I let the oven cycle on and off at least three times, then take the high and lower readings on the next cycle and average that out to see what the actual oven temp is. Most of the time, if there is a dial type thermometer in the oven it is very slow to react. After 3 to 5 cycles, they often show close to what the actual oven temp is, but the only way to know for sure is to use the more accurate digital thermometer. Most ranges with digital displays can be adjusted + or - about 35 degrees. Check your users manual for this info, but don't mess with it until you have checked the oven with a digital thermometer! Please don't bother rating this solution, as anything but a Fix-Ya drops my score. Thanks.
SOURCE: Maytag oven needs temp calibration
Take your temp knob off and look in the center of the stem and you should find a small set screw. Using a small precision screwdriver, turn the screw until you see the light come on. (You won't have to turn it far.) Turn it a little at a time, maybe a 1/16 of a turn. Leave your thermometer in the oven with the door closed and at or near the temp probe that is in the oven. This way, you are getting a true reading.
