IF YOU HEAR RAPID CLICKING...
IT MIGHT BE A BATTERY OR ALTERNATOR PROBLEM.
OTHERWISE
It might be a faulty starter.
One of the symptoms of a bad starter is a single clicking noise when you turn the key or push the start button. ... Most likely, you'll need to get your starter repaired or replaced. If you can jumpstart your car, drive to your nearest repair shop to get the problem diagnosed.
there are many other possibilities,if the above options are not helping:
Click the link below:
https://carrepairworld.blogspot.com/2021/06/why-car-wont-start-you-hear-clicking.html
this will help.Thanks.
CAR NO START PROBLEMS:----- It
can be the issue with weak battery or faulty battery or if battery is ok,then
its faulty starter causing the issue. From
start to end troubleshooting these problem i suggest you to click the link
below and follow its procedure:----- What to Do When Car Turns Over But
Won't Start? http://technoanswers.blogspot.com/2012/11/what-to-do-when-car-turns-over-but-wont.html ----------- http://technoanswers.blogspot.in/2012/02/car-starting-issues.html ------------ http://whoisbyme.blogspot.in/2012/06/car-starting-problems.html -------- http://whatisbyme.blogspot.in/2012/05/1991-toyota-trecel-engine-starts-fine.html ---------- http://howtobyme.blogspot.in/2012/05/1994-toyota-pickup-starts-fine-but-dies.html --------- http://whatisbyme.blogspot.in/2012/06/1999-chrysler-cirrus-8-ign-fuel-starter.html ----------- http://whatisbyme.blogspot.in/2012/05/2001-toyota-camry-no-start-after.html ---------- -------------- -------- http://whatisbyme.blogspot.in/2012/05/1995-lexus-ls400-running-hot.html ---------- --------- http://www.howtorepairguide.com --------- These will help. Thanks.
Car starting issues?
Car Starting Problems
1991 Toyota Trecel: Engine Starts fine but
dies when gets Warm?
1994 Toyota Pickup: Starts fine but dies in
few seconds?
1999 Chrysler Cirrus: 8 IGN Fuel Starter Fuse
Blows?
2001 Toyota Camry: No start After replacing Battery?
1989 Toyota Pickup Truck: Turns over but not
start?
http://whatisbyme.blogspot.in/2012/05/1989-toyota-pickup-truck-turns-over-but.html
Car dead and will not Start?
http://whatisbyme.blogspot.in/2012/05/car-dead-and-will-not-start.html
1995 Lexus LS400: Running Hot?
2001 Toyota Prius will not start?
http://whatisbyme.blogspot.in/2012/05/2001-toyota-prius-will-not-start.html
1996 Jeep Grand Cherokee: Engine will not start?
http://repairhelpcenter.blogspot.in/2012/06/1996-jeep-grand-cherokee-engine-will.html
Mitsubishi will not start
Probably a starter. It sounds like the starter solenoid is working, but the starter motor is not energizing.
You could try this simple trick, but Im about 85% sure you have a bad starter.
Have a buddy help you push the vehicle in neutral for a short distance. When you get it moving at a walking pace, put the transmission in Drive, and let the vehicle come to a stop. You may hear a little clicking, but thats OK, it wont hurt anything. Put the transmission back in Park and try to start the engine again. Sometimes the starter gear gets stuck on the flywheel and it wont engage when you try to start the engine. This trick may move the flywheel a little so the starter can engage.
SOURCE: jeep liberty 2007, window regulator died. What is
take off door panel and tap with a small hammer
