Remote keeps saying hood open
SOURCE: Viper SST 7701. I replaced
Try to relearn the tach by cranking the car and holding the valet switch(small black push button) until the LED lights solid.The try it again
SOURCE: I have a viper 5501 LC3 SST LCD alarm; my problem
You failed to mention the year/make/model of the vehicle so, my answer will be as general as your question. Either you have a vehicle that has a delayed dome light and , the alarm is tied to that wire or there is a problem with one of your door pin switches.
This sounds like you have a delay domelight and they used that to trigger the alarm. You domelight stays on for 20 seconds after you close the door so because it is still on the alarm thinks the door is open even if the doors are closed. you can fix that by having a tech hook up the door triggers to the door latch wires and not the domelight itself...or you can program the alarm in Menu 2 otion 3 to not sense the door ajar when you first arm your alarm.
SOURCE: i have car infiniti G35 my alarm viper 7701 v sst
You may need to adjust the sensitivity of the sensors.
SOURCE: I just received a brand
Try plugging the charger into an outlet then, plug the charger into the remote, remove, plug in, remove...Do this for approximately six(6) times or, until "charge" appears on the remote. When "charge" appears on the remote leave it pug up to complete charge.
