Model WL80T65C
49. (00110001) Cold Valve or Cold Valve & Hot Valve Faulty
The Motor Control Module has measured a voltage from the valve diagnostic circuit that
indicates the cold valve or both the cold and hot valve is faulty. The most likely cause is
that the valve harness has not been connected correctly or the valve(s) is open circuit.
Primary Source: Wiring.
Action: Check the valve harnesses are correctly fastened to the valves and
the motor control module or the pins are not bent backwards.
Secondary Source: Water Valves.
Action: Measure the resistance of the cold and hot valve coils.
Tertiary Source: Motor Control module.
Action: Replace the Motor Control module.
SOURCE: hi my washing machine saying fault 49 on it model WL80T65C
prob the capacitor faulty on motor , or start up windings on motor burnt out ,
