Rinnai Toyostove Direct Vent Heater: Laser 30 Toyostove Direct Vent Heater Shipping Logo
Posted on Jan 09, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Laser 56 EE6
I bought my Laser 56 about 2 years ago. I live in Alaska and lately it has been a bit chilly -20/-30. After a day of shopping in the nearest town we came home to find our heater with the code EE6, and our dogs shivering forlornly.  After turning the burner off and on and doing a self clean (which we do regularly!) it came on just fine. Since then it will be on for an hour or two and then poof! EE6! We've taken to sleeping on the floor in front of the monitor (much to the chagrin of our pups)  just to keep our house warm. We don't think the tank isn't too high, or low. We cleaned the flame sensor with an emery cloth... Flame sensor malfunction? Fuel flow problem? This problem happens at a higher rate the lower the temperature. Taking it in will be a rather big bother. Any ideas of things we might try?
Anonymous
Level 2:
  • Expert 126 Answers
  • Posted on Jan 09, 2009
Anonymous
Expert
Level 2:
Answers
126
Questions
0
Helped
151541
Points
215
EE 6 happens for several reasons. Most likely in your case when the stove runs for a while after you turn it back on, the code is due to and over heat. The circulating fan and cover need to be spotless. If they are then the code is due to low fuel, no fuel or dirty filte on tankor stove.
Tom Hawkins
Bethel, Alaska
[email protected]
I want to replace the original carb on my 75 MGB with a weber, should I use a water, manual or electric choke weber carb ??
It depends on where you live really. Let's say you live in Texas, the fall and winter mornings can be bitterly chilly...but by noon be hot as heck. During the summer it is hot always. If it were me I'd use a manual choke in southern areas. or if I were in Michigan I'd probably use a electric choke. I actually say that because manual chokes in a place like Michigan will get stiff, rusty or freeze without proper maintenance and shielding. I lived in Alaska and Cheyenne Wyoming and noticed in Alaska that cable chokes and linkages would bind up in extreme temperatures. But when all else fails try the Weber Electric choke.
2000 Toyota Avalon XLS intermittent starting problem
If the car does not crank at all then the anomaly could lie with the starter motor. These suckers have carbon brushes that over time will wear. Usually there are springs that keep pushing the brush onto the commutator but it is possible that the brushes are so worn that the springs have reached the max on their spring and the brushes make intermittent contact at times. That explains why it is dead sometimes and starts after you jostle the unit.
Or if you have an auto transmission you can also check out the switch that is part of your transmission that prevents car from starting unless it is in neutral. The neutral safety switch. If the latter is bogus you can either replace it or just bypass it and save the dinero.
Avalon is a great running car and ................
2answers
I need an outdoor blanket to take to an outdoor concert. It's a bit chilly this time of year so something that will keep me warm. Thanks!
This blanket is great, it has a side made of fleece and the other is waterproof so it won't get wet from the muddy ground and it'll also keep you warm!
http://www.mambeblankets.com/essentialoutdoor.aspx
Jan 29, 2013 • Garden
2helpful
I keep finding my Lazer 56 off, with the code EE6. What does that mean?
This could be several things. It could be a problem with fuel flow, the high temperature limit is activated, or a problem with the flame rod. Start by checking your filter at the barrel and the strainer in the fuel sump. If you hear a ticking or thumping noise before it cuts off, you are not getting fuel to the fuel pump. Next you can clean your flame rod with some steelwool or fine sandpaper. Lastly, make sure the circulating fan is running and nothing is blocking the air to fan. You can also clean the fan blades if they are dirty.
My laser 30 quit working suddenly last weekend. It has given error EE2, EE6 and EE13. What should I do?
Get it tuned. Sounds like it is plugged up.
If it has been more than 2 years since the last tun-up.
1helpful
TOYO LASER 56
Here is a link to the owner's manual... look it over to see what may have come unhooked. If you can't solve it you may be able to contact the business for this web site...
http://www.rural-energy.com/publications/catalog/document/270
1helpful
Toyo stove, Lazer 30 model
EE22 is a lockout code.
Unplug unit for 30 min.
You need to findout why you still get EE2 or EE6
Check fuel and filter
Still have problems call me I'm in North Pole
Dave 4889179
6helpful
Lazer 56
Hi EJAKFbanks,
I believe by your description and my 8 years experience with Toyo Stove repair that you are missing part of the firing sequence. The firing sequence for a Toyo Stove L 56 is to blink on the burner light for 7-9 minutes, then it clicks up to the medium light (amber-yellow color). The medium light blinks and that is when the fuel pump kicks on and starts to pump. If the stove ignites, the medium light will glow for a second and then drop down to the low light (green) The low light will burn for awhile and at this time you will see a blue flame in the newer heat chamber models or a red glow, and perhaps some blue flame in the older heat chamber models, then the stove will kick up to the medium light for a bit, and then to the high light. An EE6 error code will show only when the flame is extinguished after actually taking place and a burn did occur in the chamber on low. An EE6 is usually one of 2 things: 1. There is an inadequate fuel supply for the stove to maintain a low cycle burn, or the medium, or high. Each cycle consumes more fuel than the prior one. Inadequate fuel supply can be due to a restriction in the fuel line such as icing like cholesterol in a persons arteries, or a plugged sump screen, blocked fuel line or filter, too low a quantity of fuel in the tank, or a fuel line that is not all gravity feed, as in, the fuel line runs down, down, and then up a few feet to get to the Toyo. In that case, the fuel has to rely on head pressure to get to the stove. Head pressure is the atmospheric pressure pushing on the fuel in the tank to force it up against the earth's gravity forces. Solution: You can find any restriction in the line, replace the filters, clean the sump screen, put heat on the fuel line to thaw any icing blocks. 2. An EE6 can be caused by a carbon chain developing from the burner ring, flame sensor or chamber wall to any metal part in the burn chamber. A carbon chain essentially "shorts" out the ground for the unit and the Toyo will shut off on EE6. Solutions:You can bang the side of the Toyo (Old frustrated Alaskan solution) which really just jars the carbon chain loose, clean the flame sensor, clean the fuel nozzle with a straight 3 inch wire, and stick a screw driver in the igniter (red wires) hole and rattle it around real good (another old Alaskan trick). Often, those three things will get your stove running again if it is a carbon chain. The problem will likely occur again, but it will buy you some time until you can get a tune-up done. Most likely, you need a tune-up. Question: When was your last tune-up? Toyo's should be tuned up every 2 years. Tthe book says every one year, but in my experience, every two years is the best bang for the customers buck. The three year mark usually begins showing signs of metal fatigue in other parts of the burn chamber/heat exchanger system so the costs rise a little each year, unless you are a lucky Toyo owner and for some odd reason, your stove can go 3 years between cleanings without any ill effect. If you get your stove running, run it hard on High for about 2 hours to clean and burn all the carbon out. Good Luck! toyotech, North Pole, Alaska
EE2 code for toyo laser 56
Hi sammysamual,
My business is Laser Heating Service in the North Pole/Fairbanks areas of Alaska. An EE2 error code is usually fuel related. What does your Toyo do before the EE2 code shows up? If you let me know the sequence of events, I can trouble shoot the problem for you. toyotech
Top Rinnai Heating & Cooling Experts
Paul Carew
Are you a Rinnai Heating and Cooling Expert? Answer questions, earn points and help others
