2002 Toyota Sequoia Logo
Posted on Nov 26, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Cant remove third row bucket seats sequia
Remove third row seats
Anonymous
Level 2:
Sergeant:
  • Expert 271 Answers
  • Posted on Nov 26, 2012
Anonymous
Expert
Level 2:
Sergeant:
Answers
271
Questions
0
Helped
83536
Points
842
To recline the third row seats in the Ford Flex you should be able to press the control on the side of the seat.
------------------------obd2express.co.uk
http://www.obd2express.co.uk/wholesale/vcm-metal-box-ids-jlr-new-vcm-release.html
3 Related Answers
Anonymous
  • 10319 Answers
  • Posted on Jul 23, 2009
SOURCE: How do I install a third row seat in a 1996 toyota
You don't. They have special welded supports when ordered through the factory when built under the floor pan
Anonymous
  • 2004 Answers
  • Posted on Oct 07, 2009
SOURCE: i have a 2.8 surf and need the third row of seats
Visit www.ebay.com
Anonymous
  • 1297 Answers
  • Posted on Sep 02, 2010
SOURCE: I want to remove the third row seat from my 2010
cool!
how can we help?
2006 Pontiac Montana. Can I remove 1 of the middle seats?
Question edited for clarity.
Question moved to model category.
Air bags only deploy if there is weight on the seat. Yes they are removable.
Pontiac Montana SV6: how to remove second row seats ...
JustAnswer https://www.justanswer.com > Pontiac Problems
Apr 21, 2015 - HI, Attached at bottom of the answer is directions to remove the seats - below is procedure to disable airbags before beginning work ...
1 answer · Top answer: HI, You can but you have to know the resistance of the airbags, which unfortunately gm doesnt ...
Removing The Bucket Seats - Pontiac Montana SV6 2008 ...
ManualsLib https://www.manualslib.com > ... > Owner's manual
1. Pull the nylon strap or lift the recline lever. · 2. Press back on the seatback until it is in the desired. position · 3. Let go of the strap or lever.
Removing Third Row Seat From A Pontiac Montana An Easy ...
osvehicle.com https://www.osvehicle.com > removing-third-row-seat-...
Mar 29, 2023 - The most straightforward way to move the furthest back seat is to remove it from the back door and slide it out. Uncomplicate The Task: Removing ...
Remove 3rd row seat in 2004 Ford Expedition
copied this from ford forum , quite a lot of work, do your seats fold down into the floo ? if so follow this guidance
Removal and Installation
CAUTION: To prevent possible damage to the third row seat or the safety belts, make sure that the safety belts are not fastened when moving the seat to the load floor position.
CAUTION: Make sure that no objects such as books, purses or briefcases on the floor in front of the third row seats or on the seat cushion before lowering the backrest(s).
NOTE: The third row seat backrests need to be in the raised position for removal of the third row seats.
All seats
Remove the load floor panel.
Remove the jack assembly.
Remove the load floor panel latch striker bolts and the latch striker.
Remove the 3 pin-type retainers and the jack storage compartment liner.
Remove the 2 bolts in mid-floor panel support, lift on the front of mid-floor panel support to release the 3 retainer clips and remove the panel support.
I have 2 bucket seats in the middle of my 2007 montana. can i take one out?
Yes of course you can remove the seat. There is a pull at the rear of the seat in the middle (down on the frame) The pull is a loop of material. You need to pull that up with solid force, this will release the lock so you can tilt your seat forwards. Once the seat is rotated forward enough, you will be able to lift the seat out.
I leave my seat out behind the drivers seat most of the time for easy access into the back and just putting stuff in the car. Also, the side clearance height is higher than the rear hatch height.
My power third row seat don't work, I tested the motors and they work fine when power directly. When I measure the voltage at the connectors I get about +/- 10 volts, from any of the 4 switches. I verified...
Your missing something's G-404 has nothing to do with it !
Seats - Third Row
The third row seat:
  • is three-passenger seat.
  • a 60/40 bench seat.
  • folds down for more cargo area.
  • has optional power fold down seats.
Third Row Power-Fold Seat
CAUTION: Make sure that no objects such as books, purses or briefcases are on the floor in front of the third row seats or on the seat cushion before lowering the backrest(s).
The third row power-fold seat consists of the following electrical components:
  • right third row seat relay.
  • left third row seat relay.
  • right power-fold seat motor.
  • left power-fold seat motor.
  • right front third row seat switch (if equipped).
  • left front third row seat switch (if equipped).
  • right rear third row seat switch.
  • left rear third row seat switch.
For the third row power-fold seat to operate, a shared ground is supplied by the body security module (BSM) to both of the power-fold seat relays, enabling the seats to then be moved by pressing one of the third row power-fold seat switches. The third row power-fold seat operates only when the vehicle is in PARK and the liftgate glass, liftgate door or any entry door must be open.
The third row power-fold seat motors transfer movement to a drive gear assembly to raise and lower the seat backrest. The power-fold seat motors rotate a short drive cable which is connected to the drive gear assembly.
The relay's are located in Aux. relay box #2
1helpful
2answers
2004 ford expedition: changed battery, now rear seats will not go up or down. One is up the other one is down. They were working fine before the battery was replaced. Wifes car need to fix, she is...
Call the dealership and ask them how to reset the electronic on your Ford Expedition after changing the battery. Anything else is happen? Maybe like the radio wont turn on, hit the turn signals and the windshield wiper turn on. ***** things happen after replace the battery. I know what it is, it the darn wigits. GB you....stewbison
1helpful
Remove third row in 2006 odyssey
hi
its difficult to remove third row seat but either by pumping hot air to it or by sucking out the water by water ****** sponge. if its necessary to remove then better to take the car to an autorised service station
I NEEDED THE 2001DODEGE CARAVAN SPECIFICATION
2001 Dodge Caravan Performance Features -3,301 cc 3.3 liters 6 V engine with 93 mm bore, 81 mm stroke, 9.3 compression ratio, overhead valve and two valves per cylinder
-Unleaded fuel
-Fuel economy EPA highway (l/100km): 9.8
-Multi-point injection fuel system
-Main 76 liter unleaded fuel tank
-Power: SAE and 134 kW , 180 HP @ 5,000 rpm; 210 ft lb , 285 Nm @ 4,000 rpm
2001 Dodge Caravan Handling & Driving Features -ABS
-Two disc brakes including two ventilated discs
-Spacesaver steel rim under body spare wheel
-Strut front suspension with stabilizer bar independent with coil springs , beam rear suspension with stabilizer bar rigid with leaf springs
2001 Dodge Caravan Exterior Features -Body side molding
-Front and rear body color bumpers
-Driver and passenger power heated black door mirrors
-External dimensions: overall length (mm): 4,803, overall width (mm): 1,996, overall height (mm): 1,750, wheelbase (mm): 2,878, front track (mm): 1,600, rear track (mm): 1,626 and curb to curb turning circle (mm): 11,460
-Complex surface lens halogen bulb headlights
-Double sliding minivan side door
-Remote control operation opening rear ¼ windows
-Metallic paint , gloss paint , pearl paint
-Fixed rear window
-Tinted glass on cabin, rear and side
-Weights: curb weight (kg) 1,842, gross trailer weight braked (kg) 907 and max legal load (kg) 772
-Windshield wipers with variable intermittent wipe
2001 Dodge Caravan Interior Features -Air conditioning with rear outlet
-Fixed mast antenna
-Manufacturer's own audio system
-Automatic drive indicator on dashboard
-Below seat storage under passenger seat
-Cargo capacity: all seats in place (liters): 433, all seats removed (liters): 4,154 and third row seats removed (liters): 1,291
-Clock
-Dashboard full console with open storage box
-Delayed/fade courtesy lights
-Cruise control
-Front seats, rear seats and 3rd row seats cup holders
-Door ajar warning
-Door pockets/bins for driver seat and passenger seat
-Floor covering: carpet in load area
-Driver and passenger front airbag
-Bucket seat
-3-point reel height adjustable front seat belts on driver seat and passenger seat
-Front seat center armrest
-Glove compartment
-Height adjustable two head restraints on front seats, rear seats and 3rd row seats
-Internal dimensions: front headroom (mm): 1,011, rear headroom (mm): 998, front hip room (mm): 1,440, rear hip room (mm): 1,722, front leg room (mm): 1,031, rear leg room (mm): 930, front shoulder room (mm): 1,588 and rear shoulder room (mm): 1,643
-Low fuel level warning
-Low washer fluid level warning
-Internal button power locks
-Power steering
-Front power windows with one one-touch
-Front reading lights
-3-point reel height adjustable rear seat belts on driver side and passenger side
-Bench one-piece two rear seats
-Rear view mirror
-Upgraded cloth/velour seat upholstery
-Seating: seven seats
-Six speakers
-Plastic steering wheel
-Tachometer
-3-point reel third row seat belts on driver side , 3-point reel third row seat belts on passenger side , lap static third row seat belts on center side
-Front facing bench removable one-piece third row seats with capacity three
-Driver and passenger vanity mirror
-Ventilation system with recirculation setting
Thanks.
9helpful
2answers
I want to make my 1999 Mercury Villager Sport into a cargo loader, with just the front seats kept and the rest of the back empty. How do I remove the other 3 seats? So far, I can't get any of them to budge...
the middle seats come out easily. There are 2 handles you have to lift up on each of the bucket seats, they are in the front of the seat down by the seat tracks. After you lift them, tilt the seat upward in the front and rotate them backward. Then lift out of the hooks. Each seat is held down by 4 hoks.
The 3rd row seat is not designed to come out xcept by a technician. It does slide forward all the way up to the front seat. It has a sliding seat track.
First, lift the T handle under the seat cushion on the left front side of the seat. This will allow you to lift the seat bottom up all the way to lcok in the full up position.
Then, lift the lever on the same side of the seat and slide the seat forward. It will stop in 4 places.
Rear -Rear
6 inches forward of that.
another two ft to the second row seating position
full frward against the front seats.
Pleae rate as fixya if this helps.
c4253aa.gif Seat —Third Row Bench Removal
sxv~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Removal of the third row bench seat requires more than one technician.
  1. Remove the second row seats. For additional information, refer to Seat—Second Row .
  1. Remove the floor mats.
  1. Lock the seat cushion in the upright position.
    1. Lift the handle to release the cushion.
  1. Move the third row bench seat to the second row position.
    • Lift the seat track release handle.
  1. Remove the two bolt covers.
  1. Remove the two seat track front bolts.
  1. Remove the four seat track rear bolts.
    1. Position the rear seat cushion floor cover aside.
  1. Remove the third row bench seat.
Mounting third row seat in 2008 Suburban 1FL, LS 1500 - Fleet veh
I drive a 2008 Suburban LT and my company has a true work "fleet" suburban. The only difference between these two that I have is the back of the fleet vehicle has a thick rubber mat in the back with no seats. After removing the black mat I found that the channels and rods that the rear seats clip into are present. The third row seats are installed by clipping them in no bolts or tools are required.
Top Toyota Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Toyota Expert? Answer questions, earn points and help others
