Canon PowerShot S51S Digital Camera Logo
brian neville Posted on Nov 26, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Lens error message - Canon PowerShot S51S Digital Camera
Level 3:
One Above All:
The expert with highest point at the last day of the past 12 weeks.
Top Expert:
  • Canon Master 102,366 Answers
  • Posted on Nov 26, 2012
Canon Master
Level 3:
One Above All:
Top Expert:
Answers
102366
Questions
0
Helped
10433531
Points
622693
Im getting a lens error message on my h3dii ....message reads ... lens error id 21:1
Problem: dust in the gaps near lens which makes it jammed. Effect: the sceen shows blk color. Solution: just blow over it or vaccum it.
4helpful
2answers
Error message ''Lens error'' on nikon coolpix digital camera
Try cleaning any grit out of the lens mechanism with compressed air and a little wiggling of the lens. If that doesn't do it, the camera needs servicing.
Lens error message(nikon l16)
I was having a "Lens Error" with my Nikon Coolpix S10 camera and this websites' tips fixed my camera.
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Good Luck!
Sep 27, 2009 • Cameras
1helpful
Camera felled to floor lens tries but cannot retract camera turns on and off fine, error message "lens error, restart camera" it appears that until lens can function properly and error message is resolved...
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
3answers
Lens error= restart camera - this is the message I am receiveing from my cannon SX110 IS
31helpful
Lens error, restart camera
Lens error is usually caused by mechanical faults concerning lens assembly. The lens cannot extend or retract fully, the error is detected and lens error is returned.
Sometimes this can be fixed playing with the lens during extraction or retraction to help the lens asset getting back to normal.
More often the camera lens must be disassembled and re-assembled by a technician to fix the problem.
1helpful
3answers
Bonnie
I was getting the Lens Error message on my A730, even though my lens seemed to be working fine. I'd had the camera in my pocket, and apparently it tried to open but jammed. But it seemed to be OK except for the cursed Lens Error message when I'd power it on. The way I found to fix it is press and hold the "func/OK" button on the back, then turn the camera on. Now it's working again. Note that this may not work for you if your lens is actually screwed up. Mine wasn't.
Dec 12, 2007 • Cameras
Top Canon Cameras Experts
old marine
old marine
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Canon Camera Expert? Answer questions, earn points and help others
