Liftmaster 3265M Garage Door Opener opens on its own
My Liftmaster 3265M Garage Door Opener opens on its own. At first this happened maybe once every few months, Then it was more frequently. Now it is a daily occurrence to the point that I have unplugged it.
I tried using the "Lock Button," and got the green light flashing. It still opened later on its own.
I unplugged the opener overnight. Then plugged it back in this morning. So far, so good.I unplugged the opener overnight. Then plugged it back in this morning. So far, so good.
You can't post conmments that contain an email address.
? 3:10
https://www.youtube.com/watch?v=Zq_CxeTXoSM
Jul 2, 2013 - Uploaded by Mike McCarron
Might have taken a lightening strike, knocked out GFCI that was on the circuit that garage door opener was on. When I ... And sometimes after it happens it takes 30 or so seconds before the opener will work again. ... The keypad unit worked well butneither the homelink or the remote units worked.
Aug 6, 2005 - The house did not lose power and I do not believe the house was actually hit. ... the light comes on on the unit (as expected), but neither door opens or ... Afterplugging it back in, try opening the door with the hardwired button first - if it still doesn'twork, chances are your opener's taken some damage but not ...
I would just have someone come and check it out to see if it is the light or the electrical. Hopefully it is only a matter of cleaning it off and and replacing a piece or two. Good luck with the repairs and hopefully it is nothing to serious.
Yes, replace the remote battery. It is losing power, thus working at short range only. Loss of range is the key indicator for a remote battery going out.
Glad to hear it cleared up for you. Remember that random flashing is normal. It sounds like something in your garage or nearby was interfering with the radio signal. If you have added anything electrical you might want to keep an eye on it. Even things as weird as a fish tank heater can cause problems.
try adjusted the sensor controls on the sode of the unit other wise replace the logic board http://www.chamberlain-garage-door-openers.com/circuitboardcompatibilitychart.htm
