Question about Air Tools & Compressors
Campbell Hausfeld Air Compressor won't start
My compressor was running fine but it has just stopped running Does it have a fuse some where? Or what could it be ? It a 6 Gallon 2 HP Campbell Hausfeld Air Compressor
  • sue92711 Jan 09, 2009
    Thank you but that didnt work
  • peltierj373 Apr 02, 2009
    air compressor was working fine and now it will not turn on. In the past I had a cord problem and neede to replace the cord. Now I have tested and get power to the on/off switch but it will not turn on.
    I need to replace the switch right?
The compressor starting problem is common to most of the small portable compressors. Poor design and undersized components are to blame. If you have one of these units i suggest looking into a product called the Smart Start by Conrader Valves. It is interchangeable with the standard air filters and allows the compressor to start without fail. check it out- www.conrader.com.
Posted on Jul 23, 2009
  • 70 Answers
Try turning the switch off for 5 minutes the turn it back on there is usually a circuit breaker or thermal overload that can trip let me know if problem still exists
Posted on Jan 09, 2009
  • daddydug Jan 04, 2011
    Loosen the pipe between compressor and tank. Then start w/o load. There must be some type of relief valve but I haven't figured that out yet. I plan to install a petcock in this line for starting.
2 Suggested Answers
6ya staff
SOURCE:
Anonymous
  • 86 Answers
SOURCE: what kind of oil and how much to use in campbell
you can reach help for campbell hausfeld @ 800-955-6879
Posted on Aug 14, 2009
My campbell 0.33 runs but won't built a pressure
Check that the drain cock on bottom of tank is shut off,or leaking.?
Jan 28, 2013 | Campbell Hausfeld 0.33 HP 2-Gallon 100 PSI...
Husky Manual for TF291201AJ
Go to http://www.chpower.com/manualsearch/ (its the Campbell-Hausfeld website) and put TF2912 in the 'Find Model' search box and you'll get the operating instructions, parts lists and other information on your compressor.
Oct 16, 2011 | Campbell Hausfeld 5 Peak / 1.7 Running HP,...
I have a campbell hausfeld 2 gallon 135 max psi compressor suddenly stop working, when i turn the switch on, and making sure its plugged into a "hot" outlet, nothing happens, no buzzing, no sound...
No Fuse However this model is known for having the switch go bad. You can check it with a meter or Continunity tester with the unit unplugged
Hope this answers all your questions
Please remember to Rate/vote for any solution that helps you out.
Leave a comment if you need more help.
Thanks for using Fixya
Aug 12, 2011 | Campbell Hausfeld 2 Gallon Air Compressor
I'm trying to find a check valve for a Campbell Hausfels 5 hp 25 psi air compressure
take ur valve off and go to NAPA and see if u can get a valve to plumb in place of the oringinal
Jun 29, 2009 | Campbell Hausfeld 5 Peak / 1.7 Running HP,...
Piston snaped on my husky 1.7 hp 32 gallon
I have had sad service with Campbell Hausfeld. You can go to their website, type in the model number, then ask for recalls on that model. My guess is there is no recall.
If not, you might consider buying a replacement compressor motor to mount on that tank.. The tank is too good to throw away. Try Northerntools.com.
May 07, 2009 | Campbell Hausfeld 5 Peak / 1.7 Running HP,...
Could I have blown a fuse on my Campbell Hausfeld compressor
your compressor does not have a fuse, look on the side just under the plastic cover.there should be a small c/b switch, just push it in. should work.
Jan 03, 2009 | Campbell Hausfeld 26 - Gallon Air...
No air pressure past 60PSI on a 125PSI Campbell Hausfield WL61110
Your comperssor is oilless type and suffers from short cylinder / piston life. When the compressor no longer reaches cycle pressure the cylinder / piston should be replaced. These parts are available at www.chpower.com I believe that the part number is wl210300aj. Not expensive, enjoy.
Dec 13, 2008 | Campbell Hausfeld 26 - Gallon Air...
Air Tools & Compressors Logo
6,392 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
