My Sony kds-60A2000 is green dominant in color what is the cost of this repair? can I order the parts and do it myself?
SOURCE: Sony KDS-60A2000 projection TV: power led blinks 4 times
the projector bulb has gone out you need to replace it.
hope this helped
please rate well
If you need further help, reach me via phone at https://www.6ya.com/expert/mark_445a24324be9eb03
SOURCE: sony kds-60a2000 has a green tint to picture
I have had the same problem for about 6 months, and never paid much attention to it. I also noticed that when trying to change the menu color, the colors do not show up correctly.
Now it seems to be getting worse, and so I started doing some research, starting with the Sony site. That is when I found out there is an extended warranty for the KDS series (50a2000, 55a2000, 60a2000, r60xbr2, and r70xbr2) TVs because of an optical block issue, until June 30, 2010, no matter when you bought the TV.
You can see the recall here: http://esupport.sony.com/US/perl/news-item.pl?news_id=277&mdl=KDS60A2000
It seems they are extending the warranty, but not doing a recall. In other words, they aren't telling anyone, but if you happen to find the information, they will replace the optical block, if necessary. The closest I could find to the green hue issue is a purple haze on the screen.
I don't know if this is the problem, but I have scheduled an appointment to have the optical block changed. I will repost after the optical block has been changed and inform whether this is the fix to the problem.
Either way, the optical block seems to be an issue and would get it replaced whether you need it or not.
SOURCE: What does a bad optical block cost to repair on a
Call UED for price of rebuilt one 1-800-648-6657 Light Engine
SOURCE: sony sxrd (KDS-60A2000) developed yellow tint
Called them today and they set up appt for installation of the required part. They admitted a "known problem" and were straight forward about offering to take care of the problem, No fight necessary. Have the model and serial number ready off the back of the set.Call them ASAP
SOURCE: the picture appears to have a green tint to it
The optical block is failing. Contact SONY for a replacement. They have extended the warranty or replace the sets
Testimonial: "I had no idea that Sony had extended the warranty, thanks a lott! "
