SOURCE: I can't work with my
you might have to uninstall both the dvd/cd + its drivers then reinstall them actually unplug the cd/dvd from its power cable then restart your computer plug it back in your computer should activate found new hardware or
control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you can you can update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
hope this helps
SOURCE: LG GH22NS50 22X DVDRW SATA
make sure that the dvd burner is getting enough power test all leads that are attached to the dvd burner including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
your drivers may have been corrupted or you might have a virus run your antivrus program
you might have to physically unplug the leads for this cd/dvd burner then plug them back in or
you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device
click start control panel administrive tools,computer management,device manager scroll down cd dvd rom drives right click you can you can update driver,roll back driver,or
if your computer came with a motherboard disc the drivers could be on it
hope this helps
SOURCE: my lg DVD RAM GH22NS50
Hello, the problem is from the cd you inserted into the dvd rom, so it mean nothing is wrong with your DVD ROM. I think what you can do to make the DVD or CD work some how, is to use a dusting powder to clean it and try again. But thier is nothing wrong with your DVD ROM. Please vote me.
SOURCE: i have a lg gh22ns50
that seems odd if it
reads cd's it should read dvd's Click start control panel administrive tools computer
management device manager scroll to cd/dvd rom drives right click properties
then properties again then tick enable cd
digital cd audio for this cd rom device or scroll to dvd regions select
the no _ for your specific area Click on
Start, Run, and type regedit and press
Enter HKEY_LOCAL_MACHINE SYSTEM CurrentControlSet Control Class {4D36E965-E325-11CE-BFC1-08002BE10318} This folder
is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the
following names in the right hand column. Upper
Filters Lower
Filters Upper
Filters.bak Lower
Filters.bak If any of the above keys shown in step
4 are listed, right-click on them and choose Delete
If this does not fix the
problem you might try:
Click start control
panel administrive tools,computer management,device manager scroll down cd-dvd
rom drives you might see a yellow question mark ? right click you will
have options to update driver,roll back driver,or select properties general
driver or uninstall then reinstall if this does not fix the problem it might be
a registry problem if you cant see your disk drive in windows explorer
Close all open
programs
Click on the plus signs (+)
next to the following folders
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and
check to see if your CD or DVD drives have returned. You may also want to open
Device Manager and verify that the yellow exclamation and error code on the CD
or DVD drive is gone. or
you might have to physically unplug the leads for this cd/dvd then plug
them back this should activate the found new hardware wizard or
then restart your computer then reinstall your DVD/CD then reinstall the driver
for this device
a motherboard disk the drivers could be on it
administrive tools computer management device manager scroll down cd dvdrom
drives if you see a yellow question or exclamation mark?! or a red x
right click you will need to update the driver
or
hope this helps:
SOURCE: LG GH22NS50 burn all discs
Not all DVD Players are compatible with DVD-RWs. Most that I've seen aren't.
