Plzzzzzzzzz help m out.my htc screen not responding to touch;(.all the buttons r however working.
cheers
Hi, I had the same problem. Whenever, I touched my screen the wrong things would respond, then finally one day my phone locked & when I tried to unlock it the screen wouldn't respond at all.Took my phone to 3 sprint stores and all the techs couldn't help. One even accused water damage or overheating because they saw spots under my screen. But I never wet my phone so I thought it might be overheating since I do live in a warm climate. They all tried to get me to buy a new phone, which seemed like a scam. I didn't want to hard reset & lose all my data so I looked closer at the screen & noticed the spots didn't look like water spots & peeled the screen back. I noticed that the glue from around the screen actually leaked onto the screen, so I dampened one end of a q-tip & wiped the glue off the dryed it with the other end. I turn the phone back on and the screen worked fine. Try cleaning thr screen before doing a hard reset or paying for a replacement phone. It'll save you time & headache.
Hope this helps =)
Great...peeling the screen off and wiping it with dry cloth worked...thanks a lot bkshorty07...thank you very much!!!!
Hi reset your cell phone to factory setting else you have an option in HTC to reset your display settings. Yasha you need to go to the settings and then to the display option to make a new touch screen settings
but the problm is tha it is not responding to touch so i can not go to settings.is there any other way to go to settings?
how do ireset my display settigns?
Touch screen is not working for me also. Do you have any other ideas to make that work.
my touch screen is not working & i cant reach up to settings.
my touch pad is not working i hve htc p3450
touch screen not responding
my screen is not responding to anything, path is blocked so i cant go to my data or to factory reset.
Wrote to HTC.....no answer.
my partner with same phone has same problem, just after 1 1/2 year.
cant make the screen work
I have reset my phone 10 times already and i cant get into setting because the touch pad still wont work
I cannot et my touch screen to work, thus cannot use functions
Same thing here, but there are spots appeared out of some scratch points, they grew bigger in 2 months and phone stopped responding. Does this require a display replacement or is there a way to change only touch sensitive membrane covering the screen?
excellent brother.. managed to peel of the screen, wipe the glue and its as good as new again. Thank you very much
