I was baking something at 350 degrees and was suppose to take thirty minutes,it ended up cooking for 1 1/2hrs by the time it was done. What is wrong
Have you checked with an oven type thermometer for 350 degrees against the setting of 350 degrees,if its off very far then its the oven temp sensor in the upper left middle or right rear wall of the oven thats bad it looks like a small pencil type rod 2" to*' long it merely unplugs off the oven s control panel in the rear,you can test its resistance also to get an idea if it is your culprit,otherwise the oven element could have a hot spot in it and not letting all the current thru to properly heat the element,it will be dis-colored in that area
SOURCE: Oven does not maintain temperature while cooking.
Is this a gas unit? If so you might have a weak oven igniter.
SOURCE: Oven not cooking evenly, outside is getting brown but inside is undercooked
Sounds like the igniter is not operating at full capacity. What happens is that the oven does not light when it should. Instead, the oven is cooling down much too far so when the oven does light it has too heat more rapidly. This causes the outside to brown/burn long before it should.
SOURCE: i have a gas oven whirlpool sf3020ekq2 buners work but oven won't
Sounding like your hot surface ignitor is getting bad. What I would like for you to do is open the oven and take the bottom panel off. This is so you can see the hot surface ignitor. Turn the oven on and look at the hot surface ignitor it is down on the bottom right next to the burner assembly. Does it start to glow and turn cherry red? This ignitor isn't too hard to replace couple of small screws and two wires. Will have to cut the wires so disconnect the unit from the 120 volt plug. Now if it starts to glow and get cherry red hot then the gas valve is sticking and it is the one going bad. That is a little tougher to replace. Turn the gas off at the source and get your wrenches unscrew the gas valve small space so if you want remove the door by just pulling it off the hinges.
If unit is old and you don't like it anyway maybe santa would be good
to you and replace the stove oven. The gas valve is about 60 bucks or
so and hot surface is about 20 bucks. let me know how it turns out.. ken
SOURCE: My oven broiler does not seem to be working
check the bake (lower) element, mine just went out. It was easy to spot the problem once I pulled the element out, the wire had burnt off the end. Please remember to turn the power off first.
SOURCE: OVEN TURNS ON BUT WONT HEAT UP.
If your electric oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
