If the laptop battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced. Rechargeable batteries will fail if stored in a discharged state for long periods.
OverheatingWhen the CPU overheats then it will shut down (i.e. thermaloverload) and won't boot up again until it has cooled down. If this is theproblem is not fixed then the CPU will eventually fail. A faulty fan causes the problem or the fan and heat sink assembly are cloggedwith dust. Check the CPU fan to see if it spins freely, if not replace the fan. If the fan and heat sink is clogged with dust the remove the dust and make surethe vents are clear and dust free. Use a small brush and can of compressed airto do this.
Buy a usb adapter that you plug into the usb port from Tiger Direct. it
comes with software, drivers and instructions. The adapter only costs
$12.99 You can also buy a bluetooth headseat that goes around your ear
if you don't have one. When the site comes up just type: USB Bluetooth
Adapter or USB Bluetooth Headset in the white search box at the top of
the web page then click GO. When the results are returned sort them by
Price Low to High.
You need to hold down the blue "Fn" key on the bottom left, and then press the "F9" key across the top of the keyboard. This will toggle the Bluetooth (off/on/off etc).
