Question about HP Officejet 6500 AllInOne InkJet Printer
Officejet 6500 color balance - HP Officejet 6500 AllInOne InkJet Printer
  • HP Master
  • 344 Answers
On HP 6500 printers, remove screen and try heating the connection elemants with hair dryer or something similar. Nothing to hot. The led bars should restore. Here's a link on how to remove HP 6500. Do same for 6500A model, but screen is a bit different, so check out the other video for HP 6500A and 6500A plus printers:
HP 6500:
Posted on Jan 30, 2019
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • HP Expert
  • 307 Answers
For severe HP OJ 6500/6500A print quality/missing color issues there could be an air bubble in the ink cartridges, air gap between cartridge and PRINTER, or a portion of the PRINTHEAD is dry, so you should first perform a Clean PrintHead procedure from your printer control panel.
NOTE: If one or more the colors were previously dry fired during printing (i.e. if you continued printing using only a few colors to one, air may have been accidently ingested into the ink lines between the cartridge(s) and PRINTHEAD. To recover from this problem, you may have to run the Clean Printhead procedure 2-3 times.
If a problem persists then it is suggested to review the steps outlined on the following HP 920 support pages, including printhead removal/printer cleaning and service station cleaning. It is suggested you refer to printer manufacturer instructions first as the Inkjet411 procedures are provided for general guidance purposes only. A dirty service station can cause poor image quality and/or ink cross-contamination between different colors:
http://inkjet411.retailinkjet.com/?page_id=1495
If the problem still cannot be corrected, then the PRINTHEAD may be dry and may need to be flushed (i.e. with warm water as it could have dried out, but this is a function of how much you print). Remove and soak in hot water for 5 minutes...thoroughly dry printhead prior to re-installing. Retest. For more information please visit:
http://inkjet411.retailinkjet.com/?page_id=856
Worst case scenario the PRINTHEAD may simply be electrically damaged or at end-of-life (typically fails between 3,000 and 5,000 printed pages) and may require replacement, usually accompanied by error messages like Incompatible Printhead or Ink Delivery/System Failure. NOTE: The PRINTHEAD will eventually fail in time. For more information on the how the PRINTHEAD works, watch the video here: http://inkjet411.retailinkjet.com/?page_id=1983
To verify Printhead performance, run the Tap 41 diagnostic test, (Pen Status: Pen OK).....for printer model instructions please visit:
http://www.Inkjet411.com
Posted on May 24, 2013
    Scholar:
    New Friend:
  • 48 Answers
More than likely your running out of ink. Check the ink levels first.
If you have Windows 7 you can check this by clicking on the "Start" button at the bottom of the screen, click on the "HP" folder and click on "HR Solutions Center". A graft will come up showing you the printer cartridges levels. Click on the small graft chart at the top right of the screen and the graft will enlage and show you exactly the staus of the ink levels. Click "Print" at the bottom of the screen and it'll run a print test. All 4 cartridges need to be above the "Low" level. It only takes one of them to mess up the print.
If you've got plenty of ink try cleaning the printer head by:
Click "Setup" (just below and left of the LED screen) on the printer.
Scroll the Led screen to "6. Tools". Hit "OK"
Now scroll to "2. Clean printhead". Hit "OK".
This should do it..
Posted on Nov 23, 2012
  • yaron660
    yaron660 Nov 23, 2012
    Thanks. I have already done those actions - still I have a pinkish hue when printing photos. any other ideas?
2 Suggested Answers
6ya staff
SOURCE:
Geekman
Chris Hingee
  • 32281 Answers
SOURCE: HP officejet 6500 does not dispense ink
Inkjet printers need to be used frequently to prevent ink drying out and blocking the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages, then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer than replace the print head.
Posted on Nov 13, 2012
Nov 12, 2012 | HP Office Equipment & Supplies
Black ink will not print on officejet 6500
Replace print head assembly.. P/No: CD868-300018_20_2012_7_36_36_pm.jpg8_20_2012_7_37_03_pm.jpg
Aug 20, 2012 | HP Officejet 6500 Wireless All-in-One...
Officejet 6500 wireless has stopped printing ALL color.
Send the cartridges back! HP cartridges are coded and will only work with HP printers. Hp has had problems with their coded cartridges. Especially if they were manufactured overseas. Their own product won't recognize the cartridges. It is not the printer it is the cartridges.
Feb 18, 2018 | HP Officejet 6500 Wireless All-in-One...
My HP Officejet 6500 Wireless printer won't print in black when trying to print from Microsoft Office Word and Microsoft Office Excel or PDF. The ink cartridge is new. I have turned the printer off and...
I also have the OfficeJet 6500 and had the same problem. The black text was printing using a mix of colored inks instead of the black ink, resulting in a grey, fuzzy text. I finally found a solution. In each application under Page Setup, there is an option called "Format for". Mine had been set to "Any Printer". I changed that to "Officejet 6500 E709n [830E4A]" and now it prints the black just fine. I have a Mac running 10.4.11. Hope this helps.
May 17, 2011 | HP Officejet 6500 Wireless All-in-One...
The HP Officejet 6500 will now only print color copies, the black copies do not print, the officejet does not recognize the request to scan copies, the officejet will send faxes and show a fax is being...
not ridiculous as the new printer costs less than replacement cartridges
check for ink in the black cartridge
check that the driver is still connected
check for compatibility with the pc
Jun 04, 2017 | HP Officejet 6500 Wireless All-in-One...
MY NEW 6500 WIRELESS ALL-IN-ONE PRINTER ONLY PRINTS IN BLACK AND
When you give the print command did you check the properties if B&W is selected or Color
May 07, 2010 | HP Officejet 6500 Wireless All-in-One...
My new officejet 6500 wireless is not printing out color pages
If you have windows XP,vista,7 DO this.
Click on start-->control panel-->printers and faxes or printers-->right click on the ( HP Officejet 6500 Wireless All-in-One InkJet Printer ) --> choose print preferences -->Choose the TAB on the top ( Color ) --> Under that choose the print in grey scale-> choose high quality.
Now hit apply--> close --> now print in color it will work.
In case you need an idea how does the print preference screen looks like follow this link.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00532665&lc=en&cc=us&dlc=en&product=443024
Let me know if it works..
HP OFFICEJET 6500 NOT PRINTING COLOR
You need to check a few things.
first, check that the color cartridge has not run out.
Also check that in the printer settings you have not chosen to print in grayscale.
Apr 05, 2010 | HP OfficeJet 6110 All-In-One InkJet...
HP Officejet 6500 AllInOne InkJet Printer Logo
87 people viewed this question
Ekse
Thomas F. Schneider
