SewShop.com Singer Model 6606 Instruction Manual Logo
Posted on Nov 23, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Singer 6606 instruction manual
Tension settings
Level 3:
  • SewShop.com Master 18,429 Answers
  • Posted on Nov 23, 2012
SewShop.com Master
Level 3:
Answers
18429
Questions
Helped
1403863
Points
62248
Where do I tighten bobbin thread
on the outside of the bobbin case where you pull the bobbin thread around and down a small; slot to under a small flat spring
that flat spring is the bobbin thread tension and is adjusted by the screw that holds that plate on
a very small amount of turn of that screw make a large difference to the tension
However if your problem is birdnesting under the material ( total mess) then the problem is not bobbin tension but the needle tension is too loose and not pulling up the bobbin thread properly
How do i tighten the bobbin tension on Singer model 4552
When you drop the bobbin into the housing there is normally a tension screw on the side of it.
Im trying to wind the bobbin and the machine stops and an 888 message appears. How do I fix this problem?
It could mean your winding too tightly and must loosen the tension. Your operators manual will tell you what to set it at for this purpose.
Lot of thread and no stiches
you should be able to do a free download of manual from this site. Click download link and insert the 3 letter code to enable download. Singer 6202 6212 User Manual
Must be a tension adjustment problem.
How do i fix the tension
There is a dial on the left side of the machine. It is numbered 1 to 10. Adjust this to get the tension... There is also a screw on the bobbin holder but it seldom needs adjustment.
How to adjust bobbin tension
Just un ravel the hole thing and wind it back up again making shore you wind it up tightly.
Adjusting the knobs on the front of my Singer 9005
If the bottom thread is showing through, back off the tensioner, 1/2 number at a time.
How to set the tension? on my singer 7400 sewing machine.
hi.
http://www.singerco.com/accessories/instruction-manuals is the singer website where you can download the manual for your machine in pdf format. this will tell you everything you need to know about your machine. hope this helps
Aug 19, 2011 • Vacuums
1helpful
Help I need a free manual for a Singer sewing machine model 756
If you go to singer's site you can order another manual for it. They do charge for it however. Their site adddress for ordering it is http://www.singerco.com/accessories/manuals.html
You will find free online picture illustrations for how to thread this machine and wind the bobbin here http://www.sewusa.com/Threading_Diagrams/Threading_Pages/Singer_Sewing_Machine_Threading/singer_756_threading_diagram.htm
You can go to this site http://www.tandtrepair.com/700TS.html for free online instructions for things like threading and tension adjusting for your machine. They also have parts and repair manuals for sale.
There are many sites who sell the manual but none that I could find have free ones. Hopefully the picture instructions above will help you some.
Apr 29, 2011 • Vacuums
Top SewShop.com Vacuums Experts
Kardoc
ADMIN Andrew
ADMIN Andrew
Are you a SewShop.com Vacuum Expert? Answer questions, earn points and help others
