WHEN I TURN ON THE CAMERA IT SAYS LENS ERROR WILL SHUT DOWN AUTOMATICIALLY
SOURCE: Canon PowerShot SX 100 IS lens error
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
SOURCE: Lens error, restart camera
Sir,
The problem seems that miniscule dust/sand particles jam the gears which moves the lens.
It is possible to turn the lens motor by hand bit by bit and remove particles stuck in the gear.
Also try restoring the factory settings and resetting the camera and seeing if that makes the error to go away. To do that, hold down the Menu button for five seconds. This should reset everything and (hopefully) make the error stop. If it doesn't, then you've got a separate problem-- come back and let us know if the error is still there. Also, if you have photos stored on the camera's internal memory, resetting the camera will delete those so make sure to download them first.
Thanks
SOURCE: lens error, restart camera for canon power shot SX120 IS
This is probably THE most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here:
SOURCE: lens error, restart camera canon powershot
The best thing to do is to first try restarting the camera. Do not push or pull on the lens as this will often cause other issues. Do not blow air in the lens as this generally moves any dirt or dust to the back and it sits on your imaging sensor, you'll end up with poor photos after that. The best thing to do is to have it serviced so it is fixed correctly and working the way it should be. The site that is great for the Powershot Models is: www.CamerasAndParts.com They only specialize in these Powershots and they have your exact lens error problem right on the site. Try them for help. They tend to be the best deal plus they're service is wonderful. You'll pay $89 for the repair, all of the service for that model and the return shipping back to you included with them. They'd be the place for help with this one, best of luck.
Checkout this tip about digital camera error messages
Lens Error fix for Digital Camera
heatman101
