I'm trying to plug in my new ProScan television as use it as a monitor, (it has the necessary VGA computer monitor input) but I can't get a picture out of the TV...
You will need to connect to another monitor or your television to your computer with the vga lead monitor connection. Click start control panel display change display settings adjust resolution this may vary depending on your operating system You should see a no 1 and a no 2 with detect and identify keep an eye on the screen when you select the number tabs this may vary depending on your operating system
when you select the no 2 tab this should be the extended desktop always click apply after making any changes
Hope this helps
