Put the safe on your lap and bounce it on your knees and keep tying to turn the knob I had it opened in less then 10 seconds! And the batteries were dead this really does work.
Thank you now I can change the batteries
My are {4}, AA bateries
OHHH MY GAWD JUST TRIED THIS WAS FOR SURE IT WOULD NOT WORK! BOUNCED IT UP AND DOWN ON MY KNEES A FEW TIMES WHILE TURNING THE HANDLE AND DARN IT ,IF IT DID NOT COME OPEN...... THANK YOU
Wow this does work!! My hubby did it and it opened!! Thank you sooooooo much!!!!
Weird, I know, but I held the safe on my lap and jiggled my knees up and down slightly.... and it shook the latch open.... these are great safes by the way LOL bolted down is probably the safest way to go once you get into it.... but that's how I got into mine. Then used the red button on the inside of the hinge to reset the code
Thanks for the knee **** concept. 3 seconds later got it open. Cleaned it out. 2 more seconds it hit the trash bin.
I had the same problem i took a long screwdriver reached in through one of the mounting holes in the back and pressed the red button to set the combo when the yellow light on the front come on i entered a new combo pressed the A button and it opened hope it helps you. you can shine a light in one hole look through one hole and a screwdriver in one
I have a Gordon Digital Electronc Safe SKU#P45891. Have misplaced code to open. How do I get into safe?
Oh my god you guys saved my life!!!!! I jiggled the safe and it worked like a charm :) anyone know where to buy a replacement battery?
I got my code but i nee to know if i need to press a or b after typing it in my safe wont open
Removed the front plate and use you safe key!
I did that whole "jiggle it on your knee" thing after entering the pass-code & IT F**KING WORKED!
You, Teccanina801, are my new ******* hero...I've been trying to get in this damned safe for over a year!
I thought this "jiggle on your knees" solution was just a mean joke, but this comment and other success stories I heard convinced me to try it... AND IT WORKED! thank you thank you, and thank God.
What if i forgot my code, an want to change it?
device is no longer accepting pin. it beeps and the green and red light come on at the same time but safe does not open
I also have gordon safe, same sku # 45891. Locksmith?????
We are having the same problem. Cannot get the safe open with the pin. And, the safe is mounted to the wall and can't be unmounted without opening it up. No key...
I cannot find my key and The pin will not work and we need to get into the safe
have the same problem, we have a dial combination on ours, but can't find the combination. Does anyone no of a website for this manufacturer.
changed the batteries and have to reset code to open safe can you help me. i have a gordon safe.
I have had my Gordon safe for about 20 years. Everytime the batteries go dead you can't open the door. I put the safe on my knees & bounce it up & down turning the knob & it opens every time.
Work like a charm within four bounces door opened
